clutch problems
Old May 12, 2004 | 09:43 PM
herde1724's Avatar
Default clutch problems
ok just finished my swap and go to bleed the clutch, just as the manual dictates.........no luck can't get any pressure .........pedal goes down and stays down. so i changed the master cylinder, no change..........my question is does anyone have anymore ideas on wuts wrong?
Old May 12, 2004 | 10:44 PM
im_poor's Avatar
Default Re: clutch problems (herde1724)
hopefully you have a friend helping..have you checked for leaks in the lines?
Old May 13, 2004 | 08:12 AM
herde1724's Avatar
Default Re: clutch problems (im_poor)
yea no leaks in the line............i am gonna change the slave cylinder today if that doesn't work the guy i bought the motor from is gonna get a phone call from me
Old May 13, 2004 | 08:21 AM
JimBlake's Avatar
Mine does that, I thought it was normal. When bleeding the clutch I have to loop a string around the pedal to pull it back up.
Old May 13, 2004 | 08:44 AM
4drboost's Avatar
is the clutch installed propperly, release bearing, disc (i installed a bully clutch and the hub was installed on the disc backwards), are you shure everything is good inside?
Old May 13, 2004 | 09:01 AM
herde1724's Avatar
Default Re: clutch problems (4drboost)
yep everything is good in there
Old May 13, 2004 | 09:05 AM
Rtype16's Avatar
Um just a reminder when the clutch line has no pressure in it it will go to the floor and stay there. You have to manually lift the pedal back up in the beginning to send the fluid and build pressure. After a while the pedal will return on its own.
Old May 13, 2004 | 10:01 AM
herde1724's Avatar
Default Re: clutch problems (Rtype16)
yea i know that.............try bleeding the clutch for over an hour and going through 3 bottles of fluid.........still no clutch working
Old May 13, 2004 | 10:07 AM
Rtype16's Avatar
OKay just wanted to make sure. There are some noobs here everynow and than.
Old May 13, 2004 | 11:39 AM
im_poor's Avatar
where did the three bottle of fluid go? it had to go somewhere...
Old May 13, 2004 | 11:53 AM
Zerob16eg's Avatar
does it get partial pressure at all? did you bench bleed the clutch master cylinder before you replaced it?
Old May 13, 2004 | 12:26 PM
herde1724's Avatar
Default Re: (Zerob16eg)
did not bench bleed the master cylinder...........the bottle of fluid went out the other end through the bleeder valve
Old May 13, 2004 | 12:36 PM
neogenesis2004's Avatar
Im having the same problem as this cat, although i do have some pressure, its not enough to get the car in gear. Do you have to bench bleed the master and slave cylinders?
Old May 13, 2004 | 06:29 PM
4drboost's Avatar
Default Re: (neogenesis2004)
the last time i changed a slave, it was a two person job and i pushed the pedal down and pulled it up with my hand, we filled the resivoire, pushed down with the bleeder open, then at the bottom of the pedal stroke we closed the bleeder. it took about four shots and it was good to go.
Old May 13, 2004 | 10:31 PM
herde1724's Avatar
Default Re: (4drboost)
yep it was the slave cylinder got it fixed...........finally got to drive my car again, its been since thanksgiving
Old May 21, 2004 | 05:02 AM
pklaus's Avatar
Default Re: (herde1724)
HELP -- I seem have the same problem. I changed the Slave and the Master and still no pressure in the clutch - it just drops to the floor. Any suggestions on the next thing to try?
Old May 21, 2004 | 05:30 AM
JimBlake's Avatar
Default Re: (pklaus)
Without more information, I gotta suspect you didn't bleed it properly. If you didn't bench-bleed the master, then just keep trying. Sometimes it can be difficult to get air out from the master. Sometimes if you lift the pedal too quickly, you can suck air in?? Pump smoothly in both directions.
Old May 21, 2004 | 06:06 PM
pklaus's Avatar
Default Re: (JimBlake)
Thanks Jim- I did all you suggested and was unsuccessful. After pumping the clutch (many attempts), I don't get any pressure in the clutch, and a small amount of fluid comes out the bleed. What should I try next ? Should I just take it in to a pro ?
Old May 22, 2004 | 04:22 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pklaus &raquo;</TD></TR><TR><TD CLASS="quote">Should I just take it in to a pro ? </TD></TR></TABLE>You could try reverse-bleeding it...
My Saab clutch has to be reverse bled, check out this procedure.
http://www.saabnet.com/tsn/bb/...70411
That slave cylinder is down inside the bell housing, & the brake & clutch share the same reservoir. Take that into consideration but otherwise its sorta the same.
slowassciv33
May 12, 2008 08:52 PM
garyc17
Dec 18, 2006 10:24 AM
LOC714
Sep 23, 2004 12:34 PM
SikofFalln
Apr 25, 2003 02:49 PM
KooK
Jul 11, 2002 03:28 AM
