clunking noice...??>.??/>>? help!
Old Jun 15, 2003 | 07:56 PM
Doogie Howser's Avatar
Default clunking noice...??>.??/>>? help!
at first i started hearing a faint clunking noise yesterday when i would let of the gas, now it is getting louder and happens everytime i let of the throttle, it seems to be comming from the front passenger side, its in a 2000 civic with a b18c swap, i think it could be my engine mounts, what should i look for?? i also just replaced my studs on the passenger side so i removed my hub and ripped all 3 boots and havent replaced them yet, but i dont think that would make a noice
Old Jun 15, 2003 | 09:02 PM
blah13's Avatar
Default Re: clunking noice...??>.??/>>? help! (Doogie Howser)
Sounds like a worn inner joint, or something in your diff.
Old Jun 15, 2003 | 09:40 PM
slowdx's Avatar
Default Re: clunking noice...??>.??/>>? help! (blah13)
check ur lugnuts
Old Jun 16, 2003 | 01:26 PM
Briman2021's Avatar
Default Re: clunking noice...??>.??/>>? help! (slowdx)
yeah, i would check your lugnuts first, try the easy solution.
That happened to me one time after put on my exhaust, my friend said he would tighten the lugs for me, and he didnt do a very good job, and I guess it was the wheel "sliding" around with the small amount of play between the stud and the hole in the wheel.
good luck.
P.S. I wanna see your car soon, it looks tight as hell.
namewasdallas
15
Mar 7, 2010 11:33 PM
90efSI
12
Mar 11, 2007 08:53 PM
BoostedSixthGen
17
Jul 22, 2003 11:59 AM
Ronin Integra8
Dec 14, 2002 04:16 AM
Acura97GSR
May 19, 2002 03:00 PM
