Cleaning Valves
Old Apr 16, 2005 | 08:22 PM
simike's Avatar
Default Cleaning Valves
I did a search to find a good way to clean my valves while I do a rebuild. The one question I didn't find an answer for was the following. OEM valves have a black coating on them. What happens if while cleaning you remove the coating? What is it for? To prevent or at least help prevent carbon build up? The black coating is only on the head of the valve not the stem. I have seen it on a D16 head when I had it apart and it is also on the valves of my B16 head I am rebuilding now. Thanks in advance!!
Old Apr 17, 2005 | 07:58 AM
mmuller's Avatar
Mad Scientist
Default Re: Cleaning Valves (simike)
i use a brass wire brush
Old Apr 17, 2005 | 04:57 PM
simike's Avatar
Default Re: Cleaning Valves (mmuller)
I found many ways of cleaning them. I am more interested in wether or not there will be a problem if I remove the black coating? Also what the coating is for? Bump for more info.
Old Apr 17, 2005 | 05:36 PM
rainforest's Avatar
wire wheel on the stem and carb cleaner/throttle body cleaner on the face
Old Apr 18, 2005 | 06:00 AM
simike's Avatar
Default Re: Cleaning Valves (rainforest)
Bump. I am interested in what the black coating is for and would it be bad if it was removed?
Old Apr 18, 2005 | 07:56 AM
95lstegman's Avatar
i believe the black coating is an anti-friction coating.
Old Apr 18, 2005 | 08:57 AM
simike's Avatar
Default Re: Cleaning Valves (95lstegman)
So it would be best not to scratch it or remove it?
Old Apr 18, 2005 | 09:35 AM
95lstegman's Avatar
just dip it in a little glass of gasoline to get the **** off and put it back.
lolv8s
Jan 27, 2013 03:44 PM
scarney
Aug 22, 2009 09:15 PM
akshn1
Jul 4, 2009 08:11 PM
vtecn8ive
Sep 24, 2008 05:41 AM
all-mtr-teg
May 14, 2008 07:07 PM
