b18 A1 head help
Old Jan 27, 2013 | 10:28 AM
lolv8s's Avatar
10 Year Member
Default b18 A1 head help
best way to remove valve seals? (Besides needle nose pliers)
And how can I clean my head to get all of that black **** out.
Old Jan 27, 2013 | 03:44 PM
mpgmike's Avatar
Default Re: b18 A1 head help
As for cleaning, when you take heads to a competent machine shop and cleaning is ordered, they will ask you if you just want the surface gunk removed (a 30 minute tank job) or if you want it REALLY clean (sand blasted before tanking). If you just want to remove as much of it as you can by yourself, get a can of Carb & Choke cleaner and a stiff plastic brush (or soft brass brush) and go to town.
For the valves and springs, I use the wire wheel on the bench grinder.
Mike
BoostedBags
Jan 29, 2012 11:06 PM
akshn1
Jul 4, 2009 08:11 PM
Toadfart
Mar 2, 2004 01:00 PM
speedymon
Apr 15, 2003 06:32 PM
AshlandSi
Nov 9, 2001 06:52 AM
