Clean a filter
Old Apr 15, 2002 | 04:48 PM
SlowB16's Avatar
Default Clean a filter
I have a K & N filter. I want to clean it. What is the best way? can I just rinse it all out with water?
Old Apr 15, 2002 | 05:27 PM
Redline130's Avatar
Default Re: Clean a filter (SlowB16)
Doesn't K&N make a cleaning kit for it's filters?
Old Apr 15, 2002 | 05:31 PM
Regular Series's Avatar
Default Re: Clean a filter (cyber13)
Yup. You should be able to find a K & N cleaning kit at almost any auto parts store.
Old Apr 15, 2002 | 06:24 PM
SlowB16's Avatar
Default Re: Clean a filter (risingson77)
Thanks. I just did it with soap and water though. To lazy to go to the store
[Modified by SlowB16, 3:24 AM 4/16/2002]
Old Apr 15, 2002 | 06:25 PM
martini's Avatar
soap and water is not a good idea. now you have to reoil it..
Old Apr 16, 2002 | 09:28 AM
SlowB16's Avatar
Default Re: Clean a filter (martini)
It is just a normal K&N filter, why do I need to re oil it? Where do I put the oil?
Old Apr 16, 2002 | 09:51 AM
bulldog_RS20's Avatar
The filter element requires a light coat of oil to maintain it's effectiveness. The oil is included in the K&N cleaning kit.
The oil actually improves the % of filtration by trapping particles on the surface of the paper element. It's a good idea to follow the manufacturer's instructions and re-oil it.
Old Apr 16, 2002 | 02:29 PM
fixhondas's Avatar
Default Re: Clean a filter (bulldog_RS20)
you have to re-oil it when you use K&Ns cleaning crap too. I use soapy water, dry it out and then re-oil.
Old Apr 16, 2002 | 04:22 PM
acuracing's Avatar
Much of the K&N filters success is with the oil on the filter element. Just because the K&N filters have a million mile guarantee, it's only worth it's weight if you maintain it properly. The K&N kits should cost no more than $10.
Old Apr 16, 2002 | 09:52 PM
Steri's Avatar
Default Re: Clean a filter (94hondahybrid)
If you can just get the oil do that and soak it for 24 hours in soapy water then rinse it out and let it dry. But you have to add the oil after that for the filter to maintain its effectiveness.
Old Apr 17, 2002 | 06:03 AM
SPORT INJECTION's Avatar
You can use household detergent to clean it. It even says that on the k&n oil spray can. SO the oil is all you need.
liquidx
Apr 24, 2007 12:50 PM
Havokmkr
Apr 6, 2003 11:02 AM
GoLowDrew
May 14, 2002 10:37 PM
nEoMuGen
Mar 21, 2002 09:59 PM
ywwong
Jul 10, 2001 12:41 PM
