claying my motor
well i am about to see how much i can talk off my head.
i am going to clay it. but i dont know how to run on vtec when i do it.
does anyone know how too?
did a search but nothing
hey guys,i bought the HCI magazine which has cover of the new spoon integras.it has article on show how to clay with vtec on.i dont remember which issue it was...by the way,im not norman,just like his car!
Take out the set of rockers you want to clay remove the smaller of the 2 slider pins( I use a magnet to get it out of the rocker), place a small ball bearing in the rocker( ball from earing works well) and put the pin back in. You will now see the pin sticks out alittle, when you put the rockers back together it will now lock that rocker with the middle one and the middle one will lock with the end one. The middle one will push into the end one because the plunger is spring loaded. Now squeeze them together with your fingers and put them back in the head. Your now in vtec. Hope this helps
Claying won't give you valve-to-valve clearances. If you think that it's an issue.
It'll tell you:
piston-to-valve clearance
piston-to-spark plug clearance
piston-to-head/quench pad clearance
The other way of doing it will tell you piston-to-valve and valve-to-valve, but it can't tell you how much piston-to-head or piston-to-spark plug clearance you have. It's also a little more precise b/c you're measuring with a dial indicator instead of with a machinist's ruler.
It'll tell you:
For that I just remove the allen plugs on the end and remove the rocker shaft and remove all the rockers except 1 cyl. Then use this ghetto timming belt trick and 3 friendes to hold the head while you turn it over.(it would be easier if you actually put tester spring in that cyl) Now adjust the gears to the max you think you will need to run them and measure.(Use a JUNK timming belt for this)
RAxJoker
Aug 31, 2010 10:33 AM
