civic dx to si conversion
Hi folks
Need some technical help. Am putting an 89 SI engine into an 89 DX. Did the wiring mods as listed in Kenji's article. But, when turning the key the main relay chatters. This is the relay that powers the fuel pump.
Any ideas?
Thanks
Ron
ronspencer@nc.rr.com
Any ideas?
Thanks
Ron
Check to make sure the PGM-FI ground on the engine harness is tightened down on the thermostat housing.
Also, check all of the other engine grounds. That should solve your problem.
Good luck.
-kenji
Good luck.
-kenji
berts95ej
Jul 14, 2007 07:41 PM
