throwing a common code?
Old Nov 17, 2003 | 01:41 PM
social_control's Avatar
Default throwing a common code?
what up h/t...my girlfriends 98 Accord check engine light has come on, so i went and got it scanned today at a local shop. came back P1457...the mechanic said something about an EGR or something...not to clear as to what he means, could n/e one else do a better job? thanks in advance...
Old Nov 17, 2003 | 03:05 PM
bill-71SS's Avatar
Default Re: throwing a common code? (Seprioth64)
1457 on your car is the evap. system.The most likely cause is a gas cap left loose.Tighten your cap and clear the codes,if it comes back, you will need to have the evap. system checked out for a leak.
Old Nov 17, 2003 | 03:20 PM
Default Re: throwing a common code? (bill-71SS)
the guy that scanned my car said something about an EGR Valve?????
Old Nov 17, 2003 | 03:34 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seprioth64 &raquo;</TD></TR><TR><TD CLASS="quote">the guy that scanned my car said something about an EGR Valve?????</TD></TR></TABLE>
P1457 is an evaporative emmisions code. It has nothing to do with the EGR system.
Old Nov 17, 2003 | 03:42 PM
Default Re: throwing a common code? (Chiovnidca)
doing some research, the above post and some sites suggest that P1457 is an evaporative emmisions system code and means there has been a leak detected in the fuel tank area or an insufficient purge flow....english please?
Old Nov 17, 2003 | 03:45 PM
bill-71SS's Avatar
check your gas cap first,then go from there
Old Nov 17, 2003 | 04:07 PM
Stew Pidasso's Avatar
She probably either didn't tighten the gas cap all the way or filled the gas with the car running. Reset the code and see if it comes back...
Old Nov 17, 2003 | 05:40 PM
iam7head's Avatar
Default Re: throwing a common code? (Stew Pidasso)
believe it or not, the gas tank is pressureized by the freakin cap, if the cap is not fully tighten down, the sensor would throw a code thinking there's a leak or the charcoal canister blew up
Old Nov 18, 2003 | 04:39 AM
JimBlake's Avatar
Default Re: throwing a common code? (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seprioth64 &raquo;</TD></TR><TR><TD CLASS="quote">the guy that scanned my car said something about an EGR Valve?????</TD></TR></TABLE>That's why it's good to get the actual code number... P1491 & P1498 are for the EGR system. Which do you believe - the number or the description?
Actually, a loose gas cap would throw code P1456 'EVAP leak - fuel tank system'.
Code P1457 is 'EVAP leak - control canister system' which is a system of several valves, a filter, a pressure sensor, & the charcoal canister which is located under the car near the left-rear wheel. The Helm manual has about 8 pages of tests to check which valve or hose or whatever is the problem. You'll need a MityVac, a DMM, & a few jumper wires. One valve is on top of the intake manifold, the others are under the car just forward of the gas tank. The worst possibility is a pressure sensor on the gas tank - gotta drop the tank for that one.
Both P1456 or P1457 would blink 90 if you did the jumper technique to read the code.
brad8266
Jul 12, 2022 10:28 AM
Eddie99
Honda S2000
Nov 7, 2007 09:31 PM
accordv6turbo!!!
Sep 19, 2005 02:27 PM
Josh10e
Dec 13, 2004 06:59 AM
lakerschamp2000
Mar 7, 2004 02:17 PM
