Check Engine Light
Old Feb 24, 2008 | 05:23 PM
accord20o1's Avatar
Default How to check CEL OBD2 to OBD1
i was wondering how do you check the CEL on the car if you are using the OBD2b to OBD1 harness? do you need to splice the harness and jump it like that?
Old Feb 24, 2008 | 10:04 PM
accord20o1's Avatar
anyone?? because i know you cant use the obd2 scanner once you go obd1 right?
Old Feb 24, 2008 | 11:21 PM
inspyral's Avatar
Here's a good illustrated guide to retrieving trouble codes without a scanner:
http://www.c-speedracing.com/faq/06.php
This is a list of trouble codes:
http://www.c-speedracing.com/faq/05.php
Modified by inspyral at 12:42 AM 2/25/2008
Old Feb 25, 2008 | 09:05 AM
accord20o1's Avatar
only OBD1 cars have that no?
Old Feb 25, 2008 | 11:48 AM
inspyral's Avatar
Default Re: (accord20o1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord20o1 &raquo;</TD></TR><TR><TD CLASS="quote">only OBD1 cars have that no? </TD></TR></TABLE>
My car, and every other OBD-II Honda I've seen has it.
Old Feb 26, 2008 | 01:24 PM
accord20o1's Avatar
thats weird.. i have an 2001 accord i4 and its not there
Old Feb 26, 2008 | 02:22 PM
inspyral's Avatar
It's usually tucked behind the kick panel or up under the dash a little, usually in a green rubber holder.
Old Feb 28, 2008 | 09:57 AM
accord20o1's Avatar
i guess they dont have it on a 6th gen accord... i pulled off everything... i know ive seen it on civic and integra but its not on my car.. i had to jump it from the harness...
Old Feb 28, 2008 | 04:05 PM
HONDAPARTSMANMIKE's Avatar
Default Re: How to check CEL OBD2 to OBD1 (accord20o1)
What year is the car? you should have the two wire connector that you can jump some were around the pass. side kick panel area.
Old Feb 29, 2008 | 12:16 AM
accord20o1's Avatar
2001 honda accord... i pulled off everything...
Donald S.
Apr 17, 2017 05:23 AM
Tanked
Sep 10, 2012 03:30 PM
mafiasutra24
Oct 9, 2008 10:34 PM
jasony0630
Jan 19, 2008 04:33 PM
2camsaam
Oct 19, 2003 01:00 PM
