Check Engine : Code 7 On My CRX
Old Nov 20, 2002 | 11:00 AM
Cav's Avatar
Cav
Default Check Engine : Code 7 On My CRX
Hey guys
a couple of months ago my car was throwing ecu code 7 (tps sensor) so i replaced it with another used one i got off a buddy.
well now it is happening again, so i called around and its a dealer only part and the dealer wants close to 600 bucks (canadain) for it. Im selling the car soon so i obviously dont want to spend 600 on a little part
is their anything that can be done to fix this part? any suggestions, comments, or screw offs will be greatley considered
(ive heard i can tune the tps sensor with a volt meter or somthing? dunno how true this is)
Thanks Guys/Gals
The car is a 1988 honda crx dx (5spd)
all stock
Old Nov 20, 2002 | 01:32 PM
Kataku2K3's Avatar
Default Re: Check Engine : Code 7 On My CRX (Cav)
Tell the dealership to **** off.... $600 for a TPS.. If you have a local junkyard near you then just take a cordless dremel tool with a cutoff disk and slot the rivets to pull out with a slot head screwdriver... Good luck
Old Nov 20, 2002 | 01:35 PM
Cav's Avatar
Cav
Default Re: Check Engine : Code 7 On My CRX (JDMspecEG6)
yah dealerships suck
do u think i shoudl just put another used one on?
the last one i got was from a buddy who owns his own compnay and does engine swaps. he had some old ones lying around
is their any way to fix it?
Old Apr 11, 2016 | 02:06 PM
crazyhorse2011's Avatar
10 Year Member
Loved
Same problem, dealership wants 800 dollars for an EF throttle body, i told the parts man to take that TB and shove it where the sun dont shine, ******* ripoff
Old Apr 11, 2016 | 04:48 PM
DarryCar's Avatar
There's no way to fix it as it is an electrical part. The tuning I believe you are referring to when using a voltmeter is when you are installing a TPS. You have to get it in a specific position for it to work correctly and that has to be done using a voltmeter. I just replaced mine and got one off of eBay for $12.00 US. Labor must be crazy expensive in Canada.
Old Apr 11, 2016 | 05:00 PM
v4lu3s's Avatar
RTFM
have you followed the troubleshooting procedure in the service manual?
Lethalb18c1
Nov 22, 2006 08:15 PM
stevescivic
Nov 19, 2004 08:21 PM
Cav
Oct 22, 2002 09:54 PM
curiousgpnoy
Sep 24, 2002 06:31 AM
