A/C System After Car Accident?
Old Apr 10, 2016 | 12:28 AM
hondamyheart's Avatar
Default A/C System After Car Accident?
Hi all,
I had an accident three days back. The radiator took a s*** and the ac condenser too. I heard like an air release sound, It was the Freon all leaked. The question is what i have to replace in the ac system? only condenser and drier?
Car is 94 accord with h22 swap
Old Apr 10, 2016 | 01:25 AM
holmesnmanny's Avatar
Default Re: A/C System After Car Accident?
It depends on if a hose got damaged and is leaking. You have to replace whatever needs to be replaced then you need to pull a vacuum to see if there are still any leaks. Make sure to pull a vacuum for about 30 minutes after confirming there are no leaks to be sure you pull out all the moisture. Then you can recharge the system.
But, yeah, replacing the condenser along with the drier is a must, at the least.
Old Apr 12, 2016 | 02:37 AM
thanks bro
flanker
39
Mar 25, 2015 08:56 PM
NIKADEM0
Honda CR-V & Element
Jul 22, 2013 10:59 AM
Boostage
Jul 24, 2006 09:25 AM
ls-t del sol
Jun 15, 2004 11:36 AM
speedymon
Jul 5, 2003 11:10 AM
