leaking oil from the head gasket??
hey i drive a 2000 civic si i got a small problem i think my head gasket is leaking sum oil i see it slowly dripping from one saide of the gasket and it jus drips on to the tranny case its not like the car is leaving puddles of oil on the floor i jus see it dripping on to the tranny case and the car get a little too hot like i would drive it for a good 5 minutes it would be hotter then it should be i think the cat is clogged and i should change my o2 sensors too rite im getting bad gas mileage or sum
one told me this could be caused by the head gasket
thanks in advance
thanks in advance
Re: leaking oil from the head gasket?? (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub »</TD></TR><TR><TD CLASS="quote">Could also be distributor o-ring or shaft seal</TD></TR></TABLE>
exactly what i was going to say.
get some pics.
if your cat was clogged you would get bad gas mileage.
if your o2 is faulty it SHOULD throw a code.
check dizzy and see if cat is clogged
get some pics.
Re: leaking oil from the head gasket?? (doeboi365)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doeboi365 »</TD></TR><TR><TD CLASS="quote">hey i drive a 2000 civic si i got a small problem i think my head gasket is leaking sum oil i see it slowly dripping from one saide of the gasket and it jus drips on to the tranny case its not like the car is leaving puddles of oil on the floor i jus see it dripping on to the tranny case and the car get a little too hot like i would drive it for a good 5 minutes it would be hotter then it should be i think the cat is clogged and i should change my o2 sensors too rite im getting bad gas mileage or sum
thanks in advance </TD></TR></TABLE>
I have a similar problem. Just finished my B16 motor swap and test drove it yesterday for like 10 min and found out a trail of oil leak between the head and the block. I hope it's not the head gasket since I bought the motor straight from a running car.
Resident Gearhead
You've got a leaking cam seal or VTEC solenoid gasket bro, it may also be the dist. O ring. Honda headgaskets don't normaly leak oil when the go bad, they leak coolant. What you have pictured is typical of and older B VTEC leaking oil from various seals. I've been through this song and dance before - oil gathers around the edges of the head gasket and it looks like that is the source. No worries, replace the seal(s).
Re: leaking oil from the head gasket?? (mcvtec)
That things wet all the way up to the valve cover. Take it to a car wash a degrease it and then check it often so you can get an idea where its comming from. Could be valve cover, cam seal, diz o-ring or shaft seal or v-solenoid. It's pooling on the flat surface of the block so it "looks" like the hg. Remember gravity, oil wont travel up hill
Re: leaking oil from the head gasket?? (turboteg90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg90 »</TD></TR><TR><TD CLASS="quote">thats how my car is,its the vtec gasket..
Dude, your solenoid leaking isn't going to get the front of the motor up to the valve cover wet.
Dude, your solenoid leaking isn't going to get the front of the motor up to the valve cover wet.</TD></TR></TABLE>
the valve cover is not wet.
That head is wet all the way to the top of the picture. That's not from the Solenoid. How is oil going to travel forward and up from the back of the head to the front?
*subscribed* I seem to have almost this same exact leak, if not precisely THIS leak. Could anyone suggest a list of possibilities? So I can start sorting out possibilities and fetch part numbers? Thanks in advanced!
Resident Gearhead
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">You've got a leaking cam seal or VTEC solenoid gasket bro, it may also be the dist. O ring. Honda headgaskets don't normaly leak oil when the go bad, they leak coolant. What you have pictured is typical of and older B VTEC leaking oil from various seals. I've been through this song and dance before - oil gathers around the edges of the head gasket and it looks like that is the source. No worries, replace the seal(s).</TD></TR></TABLE>
Plus valve cover gasket.
Hey what it cost ya, $7. Who knows, may solve your problem. When its wet above the solenoid tho I'm guessing valve cover.Like I said before take it to car wash and degrease it. How can you tell when the whole top of the engine is covered in oil. I spray mine down every time I wash my car so it's clean and any leaks are immediatly noticable.
spray brake clean and clean it up like someone said before me. Im willing to be its the dist o-ring. If i was you i would just replace the dist o-ring, vtec solenoid gasket and valve cover gasket. This should take care of your problem. I've done a couple engines where there is a lot of oil build up and the dist o-ring is dry as no other. This shouldn't run u that much money either if you do it yourself
Re: leaking oil from the head gasket?? (XkjeldorX)
Thats your headgasket for sure. I have the same ish and the same problem happend to me in the same spot. New headgasket no more leaks.
Re: leaking oil from the head gasket?? (wh1zd0m)
Well, now that i looked at the pics more it could be also from your vtec soleniod. Its like an odd shapped gasket that connects the sleniod to the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wh1zd0m »</TD></TR><TR><TD CLASS="quote">Thats your headgasket for sure. I have the same ish and the same problem happend to me in the same spot. New headgasket no more leaks. </TD></TR></TABLE>
So are you saying the oil from his engine is defying gravity or can levitate?
No.
His engine is just dirty as hell. But it is apparent that there is oil leaking from somewhere. Thats just how my engine looked when it had an oil leak.
My vtec soleniod was leaking, clear as day, changed the o-ring on the top part and the gasket. Was still leaking and it was coming from that corner were doeboi's is pictured.Cam seal also leaked when i got the engine had to re-place that. So its a process of elimination doeboi.....
No **** it's dirty and leaking from somewhere but the simple fact is when oil leaks it leaks down, not up and forward. Just keep replacing **** hoping you get it right or use some common sense, seems to be a lack of it these days.
ya true well the valve cover gasket i replaced this summer and the rear main seal and the oil pan gasket but then i started to notice that im losing oil like alot i dont know why i mean we did an oil change when we replaced my clutch and all those seals and gaskets also i changed the spark plugs the wires and the distributor cap and rotor the gasket for that is in the dizzy rite well if sooo i anit mess with that yet...
and not in any relations with a clogged cat and bad o2 sensors would my car run slower...
