Changing from Conventional to Synthetic oil
Old 10-12-2001, 04:19 PM
New User
SchEmE's Avatar
Default Changing from Conventional to Synthetic oil
I'm currently using conventional oil and plan on switching to synthetic. Is draining the old oil and changing the filter enough? should i use a synthetic blend first? does it even matter?
Old 10-12-2001, 04:56 PM
New User
976's Avatar
Default Re: Changing from Conventional to Synthetic oil (SchEmE)
Just go ahead and drain your oil. Let it set for a while so all the oil drains - it makes it go faster if you remove your oil cap and have engine warm. No other precautions to look out for. Tell us how it works out! If you havent picked out an oil, I would recommend Mobile 1 synthetic oil & filter... Good luck!
Old 10-12-2001, 10:35 PM
New User
SchEmE's Avatar
Default Re: Changing from Conventional to Synthetic oil (B21A)
Thanks for the verification, now i can proceed as planned. I was just hoping there wasn't anything more to it that that. And due to a surprising number of recommendations, i did go with the Mobil 1 synthetic. is there a reason for the Mobil 1 being so popular or is it just brand loyalty?
Old 10-13-2001, 10:33 AM
New User
976's Avatar
Mobile 1 has great protection, and they make an almost perfect synthetic oil. No one can top em'.
LukieLuc
07-15-2008 07:22 AM
ironballz
05-13-2004 02:38 PM
matix
04-18-2004 09:32 AM
RacerXintegra2k
09-12-2002 11:34 PM
TypeR01-424
08-17-2001 07:51 AM
Quick Reply: Changing from Conventional to Synthetic oil
