changed fuel filter, still bogging!!!!!!!!!!!111111
Old Jul 5, 2004 | 07:55 PM
  #26
Ls4DrEk's Avatar
Default Re: (4inspeed)
im actually trying to figure out the same prob on my ls motor and ive swapped alot of stuff (dizzy, plugs, wires, etc. injectors, fooled with valve adj, timing) still havent found problem so if you get yours taken care of let me know
Old Aug 9, 2004 | 12:49 PM
  #27
jsdxhatch's Avatar
Default Re: (Ls4DrEk)
I have the same problem pretty much, most likely I'm going to go to the dealer, seeing as they have better diagnostic tools than I do.
gl
Old Aug 9, 2004 | 01:52 PM
  #28
hybrid0006's Avatar
Default Re: changed fuel filter, still bogging!!!!!!!!!!!111111 (nine nine si)
Before you go replacing everything on that damn motor AIM me and I will try to help you out. I had the same problem before. And there is a couple things I know u can try.
AIM: hybrid0006
MSN: jdworkz@hotmail.com
E-Mail: jeff@hybridprojekt.com
Old Aug 9, 2004 | 02:19 PM
  #29
limpy's Avatar
Default Re: changed fuel filter, still bogging!!!!!!!!!!!111111 (hybrid0006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls4DrEk &raquo;</TD></TR><TR><TD CLASS="quote">im actually trying to figure out the same prob on my ls motor and ive swapped alot of stuff (dizzy, plugs, wires, etc. injectors, fooled with valve adj, timing) still havent found problem so if you get yours taken care of let me know</TD></TR></TABLE>
me too post how to fix it.
Old Aug 10, 2004 | 05:45 AM
  #30
coupey's Avatar
ok i fixed it yesterday....
i guess from using shitty plugs, it blew them to a .065 gap...so i replaced them with NGK 7series a few days ago and the hesitation was still there, so i was like what the ****, come to find out, as i pulled one of the wires off to check the plug, i noticed that i didnt have one of the wires pushed all the way in so it wasnt getting all of the spark haha...its all fixed now
Old Aug 10, 2004 | 03:20 PM
  #31
limpy's Avatar
Default Re: (nine nine si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nine nine si &raquo;</TD></TR><TR><TD CLASS="quote">ok i fixed it yesterday....
i guess from using shitty plugs, it blew them to a .065 gap...so i replaced them with NGK 7series a few days ago and the hesitation was still there, so i was like what the ****, come to find out, as i pulled one of the wires off to check the plug, i noticed that i didnt have one of the wires pushed all the way in so it wasnt getting all of the spark haha...its all fixed now</TD></TR></TABLE>
that sucks... i know that isn't my problem... thanks for nothing. j/k...but seriously i don't know what the hell could be wrong with mine?
Old Aug 10, 2004 | 04:28 PM
  #32
coupey's Avatar
Default Re: (limpy)
what are yer plugs gapped at?
Old Aug 10, 2004 | 06:03 PM
  #33
limpy's Avatar
to be honest i'm not sure. my car is running rich i think. my problem is that in between 1k and 3k rpms, it bogs down really bad. above 3k rpms it runs fine. tried different dizzys, map sensors, injectors, tps, fpr...ect. nothing has worked.
Old Aug 10, 2004 | 06:14 PM
  #34
coupey's Avatar
Default Re: (limpy)
had the same problem and it was cuz of the gap in my plugs, you should check them, im sure that could be it....it was for me at least
Old Aug 13, 2004 | 06:35 AM
  #35
limpy's Avatar
well i figured it out. my intake mani gasket was leaking. replaced and now it runs fine.
Old Aug 13, 2004 | 12:43 PM
  #36
coupey's Avatar
Default Re: changed fuel filter, still bogging!!!!!!!!!!!111111 (limpy)
nice how did you come across finding that as to be yer problem
Old Aug 14, 2004 | 09:56 AM
  #37
limpy's Avatar
after switching everything else that is removable... i figured that was the only thing left.
Old Aug 14, 2004 | 03:59 PM
  #38
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote">after switching everything else that is removable... i figured that was the only thing left.</TD></TR></TABLE>
You didn't even check it? Just replaced it, huh?
Old Aug 14, 2004 | 09:04 PM
  #39
limpy's Avatar
Default Re: changed fuel filter, still bogging!!!!!!!!!!!111111 (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">You didn't even check it? Just replaced it, huh?</TD></TR></TABLE>
well....i lied. it worked for a little but once the engine got warm it started doing it again. WTF? does anybody know of a good website that deatails where the cavume lines go? it has got to be a vacume leak. the plugs are white showing a lean condition that can be caused by vacumelines.
Old Aug 14, 2004 | 09:55 PM
  #40
Haleiwa-Brando's Avatar
Dude,
Check your spark plugs and the gaps. Replace with new plugs and set gaps. Your stumble is caused by the misfire in the gap of the plug. I just did this in my Teg. If that is not it, which I'm sure it is, replace the spark plug wires. Keep working your way back to the distributor...though, I think a simple change of the plugs will cure the stumble.
Your problem is strickly ignition since your not smelling gas.
Old Aug 15, 2004 | 10:37 AM
  #41
limpy's Avatar
Default Re: changed fuel filter, still bogging!!!!!!!!!!!111111 (Haleiwa-Brando)
spark plugs are brand new. wires have about 3000 on them. i'm going to try new cap and rotor today.
Old Aug 15, 2004 | 11:12 AM
  #42
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy &raquo;</TD></TR><TR><TD CLASS="quote"> i'm going to try new cap and rotor today.</TD></TR></TABLE>
Didn't you do that already? Did you check them?
Old Aug 15, 2004 | 11:57 AM
  #43
coupey's Avatar
it doesnt matter how new they are if they arent gapped right
Old Aug 15, 2004 | 12:46 PM
  #44
limpy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Didn't you do that already? Did you check them?</TD></TR></TABLE>
they looked ok so i reused them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nine nine si &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt matter how new they are if they arent gapped right</TD></TR></TABLE>
brand new pre gapped. still not working right. the plugs are white... as in running lean. but the fuel pressur is dead on. i'm missing a vacume line or something.
Old Aug 15, 2004 | 01:39 PM
  #45
coupey's Avatar
what was the pre-gap?
Old Aug 16, 2004 | 07:04 AM
  #46
limpy's Avatar
same as spec. don't rem,ember exactally... but it was the same thing. I'm taking it to the local performance shop today so i'll let yall know.
Old Aug 16, 2004 | 07:44 AM
  #47
coupey's Avatar
werd, cuz i used pre-gapped ones and it wasnt correct
Old Aug 16, 2004 | 09:21 AM
  #48
boonacka's Avatar
faulty/clogged injectors, bad O2, clogged EGR, faulty TPS, faulty EACV.
Old Aug 16, 2004 | 03:20 PM
  #49
limpy's Avatar
Default Re: (boonacka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">faulty/clogged injectors, bad O2, clogged EGR, faulty TPS, faulty EACV. </TD></TR></TABLE>
changed injectors to the ones that came off my car, still does it.
o2 has about 3k miles on it
no egr(b18b)... brand new pcv valve
changed to old throtlebody off old motor, still does it.
EACV???
Old Aug 17, 2004 | 03:22 AM
  #50
boonacka's Avatar
Default Re: (limpy)
electronic air control valve or IAC
