CEL On, No Codes, No Start
Old Sep 2, 2002 | 05:03 PM
wakaru's Avatar
Default CEL On, No Codes, No Start
'92 Civic Si. Stock. One day its running, the next day its not. CEL does not go off, does not blink. ECU and ACG fuses are ok. Main Relay ok, but I don't hear the fuel pump firing. Followed the Helms troubleshooting all the way to the point where I'd have to connect a test harness. I don't have a test harness. I don't have a spare ECU.
Bad ECU? I'd like to hear the likeliest scenario from those who have experienced an always on CEL with no start.
Old Sep 2, 2002 | 06:41 PM
kinesistech's Avatar
Default Re: CEL On, No Codes, No Start (wakaru)
Sometimes electronis go bad too. Just open the ecu. If you see anything burned it probably dead.
Old Sep 2, 2002 | 06:44 PM
poison's Avatar
Default Re: CEL On, No Codes, No Start (kinesistech)
if there is no blinking and u say no 'code'. That code is a bad ecu.
Old Sep 2, 2002 | 06:57 PM
smokin rubber's Avatar
no personal experience, but I was told that a fuel pump will not throw a code.
Old Sep 2, 2002 | 08:59 PM
salbaje's Avatar
is it cranking??
Old Sep 2, 2002 | 10:54 PM
Kamin's Avatar
Default Re: CEL On, No Codes, No Start (salbaje)
have you checked spark?
Old Sep 2, 2002 | 11:19 PM
BoredNStroked's Avatar
Default Re: CEL On, No Codes, No Start (KAMiN)
Is there power to the fuel pump? If not check PGMFI relay under dash.......
Old Sep 5, 2002 | 06:19 PM
wakaru's Avatar
Default Re: CEL On, No Codes, No Start (BoredNStroked)
No power to the fuel pump, but relay was just fine. ECU was simply bad. One day it ran, the next day it didn't. The good folks at Import Auto Salvage in NC shipped me an ECU and I stuck it in today. Car was always a little hesitant to start before, but it started and ran today better than it ever has. I sniffed the old ECU after taking it out, and it smelled burnt.
Old Sep 5, 2002 | 06:24 PM
poison's Avatar
i knew it
i'm glad it's fixed nice job
94civiccpe
Jul 18, 2013 07:48 PM
guedo148
Mar 20, 2010 05:41 PM
DA_9
Mar 11, 2008 03:17 PM
CornerCarvin
Jul 27, 2007 07:31 AM
blackeg
Apr 3, 2007 07:07 AM
