code 71,71
Old Apr 16, 2006 | 04:35 PM
v-tec maz's Avatar
Default code 71,71
ok after i fix all my wiring and get the car rnning. i get code 71,72. i can smell gas in my exhuast but the car is running fine.but there is something wierd going on. my secondary o2 sensor is not even in the exhuast(open headers) and im not getting a code for it anymore. could that be causing my car to run too much fuel and run like this?
Old Apr 16, 2006 | 04:48 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: code 71,71 (v-tec maz)
Cylinders 1 and 2 are misfiring. Check your plug wires, plugs, fuel injector connectors, cap, rotor, etc.
Old Apr 16, 2006 | 04:52 PM
v-tec maz's Avatar
Default Re: code 71,71 (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Cylinders 1 and 2 are misfiring. Check your plug wires, plugs, fuel injector connectors, cap, rotor, etc.</TD></TR></TABLE>
well here is another thing. when i change the injector clip on cylinder one and too. there is no code for number two anymore. but then its not supposed to be like that
Old Apr 16, 2006 | 05:30 PM
v-tec maz's Avatar
Old Apr 16, 2006 | 05:34 PM
Dogginator's Avatar
Daisy... Daisy...
Are the spark plugs for 1 and 2 gas soaked or dry?
Have you performed a compression check? Valve adjustment?
Old Apr 16, 2006 | 05:40 PM
v-tec maz's Avatar
ill do the compression test tommorow.
Old Apr 16, 2006 | 07:50 PM
dunkd's Avatar
well running no o2 will make the car run more rich but I dont know about misfiring
Old Apr 17, 2006 | 03:53 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">well running no o2 will make the car run more rich but I dont know about misfiring</TD></TR></TABLE>
The secondary O2 sensor does not control the fuel. It simply checks the functionality of the catalyst.
Old Apr 17, 2006 | 05:02 AM
HONDA RR's Avatar
Change your spark plugs it might help .
EL Vap133
37
May 3, 2024 01:13 PM
sikcrx80
Oct 14, 2005 01:55 PM
rukawa1one
Feb 15, 2005 05:53 PM
EK_vzla
Aug 30, 2004 01:39 PM
civickid99
May 8, 2004 12:15 PM
