Cel Code 43
Old Jun 9, 2003 | 04:38 AM
tub_sephiroth's Avatar
Default Cel Code 43
I've done a search and it's fuel system related. That's too broad. I was throwing code 41 (O2 heater circuit), I put in an old O2 I had laying around. Now, it's throwing code 43. WTF. What is it? Fuel filter?
Old Jun 9, 2003 | 04:51 AM
Todd Reid's Avatar
Default Re: Cel Code 43 (tub_sephiroth)
code 43 is almost ALWAYS a bad O2 sensor.
i've had it three times, and each time (different cars) a fresh O2 fixed it right up.
good luck.
Old Jun 9, 2003 | 10:16 AM
JimBlake's Avatar
So when you put in the other old sensor you got 43, and NOT 41? Then a new sensor probably will fix you up. The preheater (code 41) seems to be fixed by putting in the other sensor, but then the actual O2 measurement is bad. So both your sensors are bad, but in 2 different ways.
Old Jun 9, 2003 | 02:37 PM
Flexmyrex's Avatar
Default Re: Cel Code 43 (JimBlake)
code 43
good luck
Old Jun 9, 2003 | 07:35 PM
Default Re: Cel Code 43 (flexmyREX)
I yanked the O2 that was throwing code 43. I double checked my O2 sensor that was throwing the code 41. I knew there was a short somewhere (since 41 is only the heater circuit, not the O2). Sure enough, one of the black wire had been completely sliced apart by the fan. I'm going to solder it back together tomorrow and see what happens.
Old Jun 10, 2003 | 09:04 PM
Well, I connected the the wires together and no check engine light yet. I went test driving it for about an hour.
Old Jun 11, 2003 | 03:49 AM
JimBlake's Avatar
Cool. Lots of times its the actual heater element that's busted. Sounds like yours was just a broken wire.
Old Jun 11, 2003 | 02:21 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Results for code: 43
Manufacturer
Honda - Engines: 1.5L - (EW1, EW3, D15A2, D15A3) 1.8L - (E53) & 2.0L - (B20A5, B20A3)
Description: Fuel Supply System (Except D15B1, D15B2, D15B6, B20A5, B21A, D16A6)
Manufacturer
Honda - Engines: 1.5L - (D15B1, D15B2, D15B6, D15B7, D15B8, D15Z1) 1.6L - (B16A3, D16A6, D16Z6) 2.0L - (A20A3, BS, BT, B20A5) 2.1L - (B21A) 2.2L - (F22A1, F22A4, F22A6, F22B1, F22B2, H22A1) 2.3L - (H23A1) 2.7L (C27A4)
Spug
May 26, 2012 12:15 AM
s14hybrid
Nov 24, 2004 05:16 AM
Mr. Softee
Dec 31, 2003 02:46 PM
HXMan
Jun 16, 2001 07:46 PM
