CEL code 22?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 »</TD></TR><TR><TD CLASS="quote">hey i dont have my service manual on me and was wondering what this code was? 97 civic runnin obd1 p28. code 22</TD></TR></TABLE>
code 22 = (VTPS) VTEC Pressure Switch (the green plug on the vtec solenoid)
what motor are you running in your 97 civic?
also, what do you think might be causing the CEL?</TD></TR></TABLE>
well first is the obvious.....is the VTPS plugged in? if it its, then is your car wired up at the ecu for VTEC at all? I should ask, how long ago did you perform the engine swap ?
well, i had the motor in before, pulled it out and built it, then put it back in, only thing i did different this time was i'm now using a P28 instead of a P72. could the p28 be deffective?
Could be but before you jump and mess with the ecu, check the basics....you know, wiring, the pressure switch, oil pressure, etc. Odds are it's probably to low on oil or something like that.
i have noticed that when i start the car, the oil light flickers and goes away and doesnt come back. it only happens when i start the car. could my oil feed line have anything to do with it?
Not sure, but check your oil level. Alot of times when cars ( mostly GSR's) come to my shop with a cel, it comes out to be a code 22. When I check the oil level, it turns out to be about 2 quarts low and in some cases, almost dry. But again, this is just to help you get pointed in the right direction.
drumminforev
25
Nov 11, 2006 09:19 PM
