CEL code 22?
Old Sep 22, 2003 | 10:28 PM
reaction360's Avatar
Default CEL code 22?
hey i dont have my service manual on me and was wondering what this code was? 97 civic runnin obd1 p28. code 22
Old Sep 22, 2003 | 10:36 PM
Katman's Avatar
Default Re: CEL code 22? (reaction360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">hey i dont have my service manual on me and was wondering what this code was? 97 civic runnin obd1 p28. code 22</TD></TR></TABLE>
code 22 = (VTPS) VTEC Pressure Switch (the green plug on the vtec solenoid)
what motor are you running in your 97 civic?
Old Sep 22, 2003 | 10:48 PM
Default Re: CEL code 22? (Katman)
i've got a mildly built b16a with a gsr head. w/ a t3 turbo. thanks for the info.
also, what do you think might be causing the CEL?
Old Sep 22, 2003 | 11:13 PM
Katman's Avatar
also, what do you think might be causing the CEL?</TD></TR></TABLE>
well first is the obvious.....is the VTPS plugged in? if it its, then is your car wired up at the ecu for VTEC at all? I should ask, how long ago did you perform the engine swap ?
Old Sep 23, 2003 | 12:50 AM
well, i had the motor in before, pulled it out and built it, then put it back in, only thing i did different this time was i'm now using a P28 instead of a P72. could the p28 be deffective?
Old Sep 23, 2003 | 08:03 AM
1bad-eg's Avatar
Could be but before you jump and mess with the ecu, check the basics....you know, wiring, the pressure switch, oil pressure, etc. Odds are it's probably to low on oil or something like that.
Old Sep 23, 2003 | 10:41 AM
Default Re: CEL code 22? (1bad-eg)
i have noticed that when i start the car, the oil light flickers and goes away and doesnt come back. it only happens when i start the car. could my oil feed line have anything to do with it?
Old Sep 23, 2003 | 12:33 PM
1bad-eg's Avatar
Not sure, but check your oil level. Alot of times when cars ( mostly GSR's) come to my shop with a cel, it comes out to be a code 22. When I check the oil level, it turns out to be about 2 quarts low and in some cases, almost dry. But again, this is just to help you get pointed in the right direction.
Old Sep 23, 2003 | 01:00 PM
ok i'm f*ckin stupid, i figured it out, i wired up my afc wrong. but thanks all for the help.
mouab18c1
Jul 18, 2010 08:16 PM
drumminforev
25
Nov 11, 2006 09:19 PM
hondaadnoh
Jan 6, 2004 02:44 AM
1 2 NV
Jun 16, 2002 08:36 PM
