Carbon Build Up On Pistons
Old May 18, 2012 | 06:49 AM
dem0nk1d's Avatar
Default Carbon Build Up On Pistons
What's the best way to remove most or all the carbon build up on these pistons without taking them out of the block?
I tried soaking them in WD40 and while they were at TDC lighting scuffed them with a 000 scotchbrite pad. Due note the areas with no carbon come out fairly clean.
I'll be rebuilding the topend so i can sell the car.
Old May 18, 2012 | 09:39 AM
civickiller's Avatar
Default Re: Carbon Build Up On Pistons
go get your toothbrush and scrub the piston tops with some simple green
it may not be perfect shiny new.
so why u doing this if youre going to sell it?
Old May 18, 2012 | 10:03 AM
Muckman's Avatar
Moderator in Chief
brake cleaner + non abrasive scotch brite pad
Id be more worried about cleaning up those sleeves to make a clean mating surface.
Old May 18, 2012 | 10:20 AM
dem0nk1d's Avatar
yeah i was going to head off to the store after work and look for the yellow 3m bristle roloc. I hear good things about them cleaning up hard surfaces. I hear the old method and pads are not ideal to use on vital surfaces anymore.
OLD
NEW
Unless you think the old disc type will be okay
Old May 21, 2012 | 09:22 AM
Skalabala's Avatar
Pistons look quite clean to me, I would be more worried about the sleeves?
Old May 22, 2012 | 10:00 PM
hondaciviceg559's Avatar
engine degreaser
lude98SH
Jul 31, 2007 12:50 PM
EK FLY
Jan 31, 2006 05:42 PM
notguilty411
Jul 31, 2005 05:40 PM
KayOs
Oct 4, 2001 10:12 PM
