car wont start, no compression.. help?
Old Nov 2, 2008 | 03:04 PM
TcUiRvBiOc's Avatar
Default car wont start, no compression.. help?
my car has been running great since i bought it with no smoke or anything ran real strong for a b16 then i went to start it yesterday and it cranked like it was about to start then just lost all compression and started turning over almost like it had no spark plugs in it.. i checked for spark and fuel and was getting both then did a compression test and the numbers r all over the place #1 was at like 40 and #2 was at like 120 and #3 at 90 and # at 70, i think its the headgasket but would like more opinions b4 i pull it apart. i was wondering if maybe the head wasnt torqued down enough.. was thinking the head might b loose but why would it do it on start up and run so strong b4 that? help please?
Old Nov 3, 2008 | 06:38 PM
TcUiRvBiOc's Avatar
Default Re: car wont start, no compression.. help? (TcUiRvBiOc)
anybody?
Old Nov 3, 2008 | 07:36 PM
srmofo's Avatar
do a leak down test
Old Nov 6, 2008 | 02:36 AM
civicguy's Avatar
Default Re: car wont start, no compression.. help? (srmofo)
are the valves adjusted right?
Old Nov 6, 2008 | 05:26 AM
WERA689's Avatar
Why does "timing belt" keep popping into my head?
Old Nov 6, 2008 | 06:22 AM
srmofo's Avatar
Default Re: car wont start, no compression.. help? (WERA689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WERA689 &raquo;</TD></TR><TR><TD CLASS="quote">Why does "timing belt" keep popping into my head?</TD></TR></TABLE>it could of jumped a few teeth...that would explain the wierd compression numbers
Old Nov 6, 2008 | 03:23 PM
TcUiRvBiOc's Avatar
thanx.. yeah ill go out and take a look at the cam gears, i havent even messed with it yet cuz i dont really have time but this motor is sold to my cousin already so i can start building the car.. so hopefully its nothing major haha
Old Nov 6, 2008 | 03:28 PM
TcUiRvBiOc's Avatar
it doesnt look like it jumped at all if it did it is only a tooth and it wouldnt do that would it?
Old Nov 6, 2008 | 09:17 PM
MR_FIX_IT's Avatar
no, one tooth off wont give u numbers like that. I would def do a leak down.
Old Nov 7, 2008 | 02:02 PM
TcUiRvBiOc's Avatar
Default Re: car wont start, no compression.. help? (MR_FIX_IT)
ok so i just went out to finally mess around with the car and put the plugs back in to c if it would start and it fired right up, then did a compression test again and 1-120 2-125 3-130 4-125 now theyre all pretty close but theyre very low arent they? why would it have no compression then a few days later start right up? really wierd! any ideas?
Old Nov 7, 2008 | 02:32 PM
TcUiRvBiOc's Avatar
ok now i just went and let it warm up all the way and did another compression test wide open throttle and got 220 across the board perfect! im very happy with that but still concerned cuz i dunno why it acted up in the first place, im sellin this to my cousin so i wanna make sure its right..
Old Nov 9, 2008 | 05:27 AM
MR_FIX_IT's Avatar
does it smoke or anything when it runs??
Old Nov 9, 2008 | 07:47 AM
TcUiRvBiOc's Avatar
no not at all! im gonna do a valve adjustment today but its still so wierd to me why it did it in the first place, would a drastic weather change have anything to do with it cuz its just started getting really cold here? now it doesnt smoke it runs perfect i checked the torque on the head and everything is perfect, timing is perfect... i dont get it
Old Nov 9, 2008 | 10:20 AM
MR_FIX_IT's Avatar
i highly doubt the weather would make any difference. but wierder **** has happened. i would check ur valve lash. a b16a2 should be .006 -.007 on the intake cam and .007 - .008 on the exhaust cam.
Old Nov 9, 2008 | 12:36 PM
TcUiRvBiOc's Avatar
yeah im just gettin ready to go out and do that now.. thanx
Old Nov 13, 2008 | 01:57 PM
TcUiRvBiOc's Avatar
just checked the valve lash and everything is perfect! it runs great like it did before this happened.. still worried though cuz dunno why it happened in the first place
Old Nov 13, 2008 | 04:06 PM
MR_FIX_IT's Avatar
the only thing i could think is maybe some rings were sticking ???
Old Feb 22, 2009 | 04:32 PM
Peakr's Avatar
New User
I'm having this same issue with 95Honda Civic, D16Z6 engine. Compression as follows. #1-54,#2-78,#3-59,#4-120. Spark and fuel is fine. Timing belt in tact. I was experiencing a loss of power the previous day then on the next day I started it up, got down the block and engine just died. You can hear a miss when engine is turning over. You'd think with low compression, spark and fuel it would still fire but I get nothing. Any help or ideas appreciated.
bingles
20
Nov 11, 2015 11:30 AM
NipponRacing
33
Apr 12, 2007 04:35 PM
jk11blueboi
Dec 7, 2006 10:05 PM
skunk2415
Sep 9, 2006 05:13 PM
rcoolb2002
Jul 18, 2005 02:28 PM
