Car wont start need help
Old Nov 21, 2008 | 01:15 AM
JayDeeEmm's Avatar
Default Car wont start need help
Ok this is concerning my friends car that I am trying to help him get running again
it is a 1995 civic EX (D16Z6)
ok here whats going on he installed headers and the car now wont turn on but I doubt this problem has anything to do with that
First I checked all grounds and fuses all fine. Fuel pump turns on its good. There is a pulse in the injectors so everything is fine.
Changed the battery still no go
Changed the Spark plugs still no go
Checked for Spark still no go
was told he raced a guy earlier and mishifted into second at 70mph only for half a sec..
ok so checked compression
all showed good around 175ish except for second on which showed lower but 150ish is not that low car should still start
checked another theroy bought Engine starting fluid and sprayed in throttle body to double check it was not a fuel problem but still cranking and not turning
checked the firing pattern everything is good
When cranking black smoke comes out of exhaust. Smell lots of gas(white/greyish smoke from headers) smoke appears to be comming from inbetween the shorty header and the w/e the pipe is called before the cat there is no gasket in between but I highly doubt that is the problem.
double checked his spark wires on my CRX it started it just fine
I also forgot to mention another friend that was helping me was truely a dumbass and lubercated the threads on the spark plugs but got that all cleaned up
I am clearly out of ideas anybody know something that could be wrong?
Old Nov 21, 2008 | 12:34 PM
JayDeeEmm's Avatar
anybody?
Old Nov 21, 2008 | 07:53 PM
JayDeeEmm's Avatar
WOW nobody?????
Old Dec 17, 2008 | 11:18 AM
Gunner142's Avatar
Yeah dude im having the same ****ing problem with my 92 prelude, But we can get it runing by choking it..
fire_king
Engine Management and Tuning
Mar 8, 2012 02:45 PM
91_e_f
Apr 6, 2011 11:32 PM
JayDeeEmm
Nov 30, 2008 12:27 AM
PinkMaggit
16
Nov 28, 2008 05:25 PM
98civichb
10
May 22, 2008 05:26 PM
