Car Won't Start
Old Sep 19, 2004 | 02:31 PM
  #26
zm_dawg's Avatar
alright i just tested the coil by taking off a spark plug wire and plugging it into the tower under the distributor cap. I then put the other end on a spark plug and laid it on my valve cover. I put a wire from the neg. of the coil and touched the other side to ground. The wire sparked from the neg. to where i grounded it , but the spark plug just sat there on the valve cover. So I guess the coil's burnt out right?.....is there anything i should look into before buying one?.....and do I buy OEM or will autozone be fine.....or possibly a used one?
Old Sep 19, 2004 | 02:53 PM
  #27
LudeEFv2.4's Avatar
My old title sucked.
Default Re: (zm_dawg)
As far as electrical goes, OEM Honda parts are the only way to go. It's not cheap either.
Old Sep 19, 2004 | 02:55 PM
  #28
LockStock99Si's Avatar
Default Re: Car Won't Start (zm_dawg)
Honda dizzy's go all the time...mine went 2 weeks ago
Old Sep 22, 2004 | 04:32 PM
  #29
zm_dawg's Avatar
MY CAR Still will not start. I got a used coil from arunto he said was used for about 1k miles. .........Same ol ****......anyone able to lead me in the right direction....the only thing i notice is that when I try to crank it and then turn the key off the engine gives a little kick. It kicks back and shakes the car....i have no clue what it could be......is it time for me to take this thing in?
Old Sep 22, 2004 | 11:11 PM
  #30
zm_dawg's Avatar
think i'm just goin to look at the ignitor now.....any other clues?
Old Sep 23, 2004 | 02:16 AM
  #31
LudeEFv2.4's Avatar
Is your timing belt broken? You said you do have fuel pressure rite.
Old Sep 23, 2004 | 07:19 AM
  #32
EFin' Kyle's Avatar
Default Re: (LudeEFv2.0)
i had the same problem and i replaced my alternator and what i found out was that my rotor in my dizzy came loose or sumthin and also at the same time for some reason the ecu or sumthin that tells the #1 injector to spray wasnt. get those checked.
-Kyle
Old Sep 23, 2004 | 09:38 AM
  #33
zm_dawg's Avatar
I'm gonna check the ignitor......my rotor is fine.....not sure how your ECU did that....i don't have a conversion harness for the one that came with the swap......but i'm pretty sure my ECU isn't bad
Old Sep 29, 2004 | 11:25 PM
  #34
Jay84ever's Avatar
Check your start.
Old Sep 30, 2004 | 01:25 AM
  #35
LudeEFv2.4's Avatar
Default Re: Car Won't Start (Jay84ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay84ever &raquo;</TD></TR><TR><TD CLASS="quote">Check your start.</TD></TR></TABLE>
we've already figured out that the motor cranks.
Old Oct 8, 2004 | 12:25 PM
  #36
zm_dawg's Avatar
after being gone for a week visiting friends at a few campuses.....got home and put the ignitor in that i got.......and p ut on some OEM spark plugs....and she started and died...then started it up.......ran like **** for a min cause i prolly had it flooded.......and then i revved her up.......people in my complex are prolly pissed that the dam thing prolly started tks to everyone that put forth some input
Old Oct 8, 2004 | 06:17 PM
  #37
PrettyLude's Avatar
glad to see its done
Old Oct 8, 2004 | 09:55 PM
  #38
zm_dawg's Avatar
wow.....it feels good lol....now if only I could get the occasional RPM stick figured out.......someone mentioned something awhile ago about the IACV screen being clogged up or somethin.........any insight on this?.....As I accelerate through 1st it'll stick between 3-4k and i'm forced to shift into 2nd.....and then it occasionally does it in 2nd....so I head to 3rd...but as soon as I downshift to 2nd...it takes off......but i will suggest not trading your hatchie for a 2000 malibu...just not the same lol
H0nda_Crazy
Sep 1, 2014 06:55 PM
egbarteezy
Apr 5, 2011 05:01 PM
KING_LIAN
Feb 23, 2008 02:59 PM
lilgreenlude93
Apr 7, 2004 10:20 PM
2camsaam
Sep 15, 2003 03:23 AM
