car wont start
Old Dec 10, 2003 | 09:00 PM
eazye5591's Avatar
Default car wont start
ok my set up is a d15z1 block with a d16z6 head and when i try to turn it on all you hear is the starter spinning but the engine doesnt crank i got 2 new starter and they both do the same thing what do u think it could be?
Old Dec 11, 2003 | 05:34 AM
JimBlake's Avatar
Default Re: car wont start (eazye5591)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eazye5591 &raquo;</TD></TR><TR><TD CLASS="quote">... all you hear is the starter spinning but the engine doesnt crank...</TD></TR></TABLE>When you say the engine doesn't crank, that means the starter runs but is doesn't engage the flywheel so the engine isn't turning? Usually that's a bad starter solenoid, but since it keeps happening with 3 different starters... That has to be something like broken teeth off the flywheel.
Old Dec 11, 2003 | 11:39 AM
b18cx's Avatar
Default Re: car wont start (JimBlake)
Is the motor spinning over with the starter? No compression maybe? timing belt way off?
Old Dec 12, 2003 | 01:11 AM
eazye5591's Avatar
the flywheel is fine and all and yea the timing belt is loose and when i mean loose meaning you can just slide the belt off , ive been trying to loosen the tensor bolt cuz is hard to loosen i shaven the bolt so now its hard to get the 14mm on it and isnt budgen i trie the gator grip thing and all it did was just shave it some more , do u think its becuz the timing belt is way loose?
Old Dec 12, 2003 | 01:13 AM
eazye5591's Avatar
Default Re: car wont start (b18cx)
naw aw all its you hear is the stater whining up u dont hear the whole motor like trying to turn on
Old Dec 12, 2003 | 03:47 AM
JimBlake's Avatar
OK, I was confused. When you said the engine doesn't crank, I thought you meant that the engine doesn't crank...
So now it sounds like the starter is cranking the engine, but the engine's not starting. If your timing belt is way off, you might not have any compression. Then when the engine cranks, it just spins fast as if your spark plugs were out. Is that what's happening? Or is the cranking OK with compression, it just doesn't start?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eazye5591 &raquo;</TD></TR><TR><TD CLASS="quote">... do u think its becuz the timing belt is way loose?</TD></TR></TABLE>Yeah, I think the timing belt is loose because you've messed up the tensioner bolt. You're probably going to have to take the crank pulley & front covers off so you may as well change the timing belt. Cross your fingers & hope you haven't bent any valves.
Old Dec 12, 2003 | 10:01 AM
eazye5591's Avatar
naw the tensor bolt is on their tite but do u think the timing belt is the result of it not cranking?
Old Dec 12, 2003 | 10:07 AM
JimBlake's Avatar
I'm not sure about D-engines, but usually the tensioner bolt works like this... When you loosen the bolt, a spring pulls on the tensioner pully, then you tighten the bolt. The belt might be loose because it's stretched from age. If your belt is loose, you NEED to get the tensioner bolt loose so your tensioner pulley can take up the slack. And, since it's been loose, you need to check to make sure your camshafts haven't jumped timing.
Old Dec 12, 2003 | 10:20 AM
eazye5591's Avatar
thankx man ey one more question i wanted to how can hook up the vtec wire becuz if i do get it started i wont be runnin vtec , on the vtec soleniod theres a green with a yellow stripe wire thats cut and on the wire that goes for distributor the same was cut too , if i connect them together would my vtec engage
Old Dec 12, 2003 | 10:22 AM
eazye5591's Avatar
do u know what i can use for the tensor bolt becuz the bolt is shaven and my sockets aynt grabbin nuttin
jerryp777
Apr 20, 2010 11:37 PM
Philip
10
Dec 30, 2006 05:01 PM
drumminforev
Oct 3, 2006 09:37 AM
kmf0211
Jul 3, 2005 03:39 PM
