car w/ swap idles high
Old Aug 29, 2003 | 04:24 PM
methos713's Avatar
Default car w/ swap idles high
i have a 95 si w/ jdm b16 swap...itr cams, itr ITmanifold, gsr tranny 6 puck....and i'm running a stock p28 ecu...my car idles from 1500 to 2000 rpm...and when the car is at a red light or not going anywhere...the rpm stays either above 1500 or at 2000 rpm. Don't know what the problem is...try moving the distributor forward and backwards...and tried screwing that one screw on the manifold...but it wouldn't work...then i put the jdm p30 ecu in...and it goes from 2000 rpm to 3000 rpm hella fast...plus the knock sensor is not connected and also the o2 sensor....any info would be great.
thanks.
Old Aug 29, 2003 | 05:08 PM
ScottFern's Avatar
Default Re: car w/ swap idles high (methos713)
any CELs ?
Old Aug 29, 2003 | 05:23 PM
Hybrid Invasion's Avatar
vacuum lines possibly?
Old Aug 29, 2003 | 05:35 PM
92KillerBee's Avatar
Default Re: car w/ swap idles high (Hybrid Invasion)
i will check all the vacums lines and than see what sup
Old Aug 29, 2003 | 05:52 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Invasion &raquo;</TD></TR><TR><TD CLASS="quote">vacuum lines possibly?</TD></TR></TABLE>
thats probably your best bet, since you already tried the idle adjust screw
Old Aug 29, 2003 | 06:05 PM
MaxSterling's Avatar
IF you have no CEL then this is you problem:
your throttle cable is stretched...and keeping the throttle body from closing. and thus idling at higher rpms
Old Aug 29, 2003 | 11:59 PM
methos713's Avatar
Default Re: car w/ swap idles high (RoyFokker)
thanks for the replies...i'll check the vac. lines and the throttle cable. with the jdm p30 ecu...the check light comes on...and with the p28...the check light doesn't come on till later...like when i drive and slow down...or step on the brake after awhile then it comes on...don't know wat the problem is...but will check to see wat codes they are throwing.
JoSi
12
Nov 28, 2025 03:18 PM
KeithsDAteg
Apr 11, 2005 10:00 PM
dstring20
Sep 15, 2004 08:43 PM
H22CL
Jan 25, 2004 11:28 AM
civicdragger818
Feb 9, 2003 10:29 PM
