car threw code 7...tps..
Old Oct 31, 2003 | 08:44 AM
VRD^don's Avatar
Default car threw code 7...tps..
okay after doing a manual swap to the car..also installed new ignition system...it threw code 7 which has to do with the tps sensor right..the car idles fine..but when i drive it regularly..the car sputters around 2000-3000 rpm..the problem would go off and on..also makes the car run very rich..sometimes it would do it and sometimes it won't...thinking about replacing it..or adjusting it..anybody here know how to..things i need...this is killing me...
Old Oct 31, 2003 | 01:54 PM
Katman's Avatar
Default Re: car threw code 7...tps.. (sohc_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_vtec &raquo;</TD></TR><TR><TD CLASS="quote">okay after doing a manual swap to the car..also installed new ignition system...it threw code 7 which has to do with the tps sensor right..the car idles fine..but when i drive it regularly..the car sputters around 2000-3000 rpm..the problem would go off and on..also makes the car run very rich..sometimes it would do it and sometimes it won't...thinking about replacing it..or adjusting it..anybody here know how to..things i need...this is killing me... </TD></TR></TABLE>
make sure you haven't mixed up the TPS & MAP sensor plugs. They both use the same style round plug. Check to see if you mixed them up.
Old Nov 2, 2003 | 12:44 PM
VRD^don's Avatar
Default Re: car threw code 7...tps.. (Katman)
no i did not mixed them up..i didnt even touch them when doing the swap..
Old Nov 2, 2003 | 06:15 PM
HatchBox's Avatar
Skoobie no more...
maybe try getting a new throttle positon sensor. see if that clears the code 7
Old Nov 2, 2003 | 10:17 PM
CleenSi
Guest
Posts: n/a
Default Re: car threw code 7...tps.. (ind3ciso)
try changing the timing?
Old Nov 2, 2003 | 10:25 PM
Kendall's Avatar
I have to agree with ind3ciso, Honda TPS's damage easily.
EGKREW
Oct 31, 2008 05:56 AM
civicx
Oct 4, 2005 03:12 PM
CiViC SiR
Jul 27, 2003 01:19 PM
91civicEX
Jul 8, 2003 08:27 PM
foesicks
Jun 4, 2003 09:47 AM
