Car takes forever to turn over
my car takes about 5-6 seconds to turn over,starter works fine, no problem
starter is grounded ok
only CEL im throwing is Engine Control Temp Sensor.
Specs
Walbro 255 LPH Fuel Pump
I modified my FPR to compensate the pressure
i dont know what else it could be...my coolant is green and my oil is clean so its not lack of compression due to a blown headgasket...what could it be?
Modified by swatteamtimmah at 6:42 PM 2/26/2006
Specs
ok when you say "turn over" does that mean it takes 5 to 6 seconds for the starter to begin spinning the engine
or does it mean it cranks normally, but the engine does not "fire" for 5 to 6 seconds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">ok when you say "turn over" does that mean it takes 5 to 6 seconds for the starter to begin spinning the engine
or does it mean it cranks normally, but the engine does not "fire" for 5 to 6 seconds.</TD></TR></TABLE>
starter cranks for about 5-6 seconds and then fire's up , i have a small vac leak but would that cause it not to fire for so long?
can you verify that fuel pressure builds quickly. There is a slim chance the fuel filter could be a bit plugged. Also, go after the temperature sensor code. Try to tackle the easy things first. sounds like you may be overcomplicating things a little.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">can you verify that fuel pressure builds quickly. There is a slim chance the fuel filter could be a bit plugged. Also, go after the temperature sensor code. Try to tackle the easy things first. sounds like you may be overcomplicating things a little.</TD></TR></TABLE>
ill replace the ECT sensor tommorow, i doubt it could be the fuel filter though i installed a new one less then a month ago.
Stann
Honda Civic (2001 - 2005)
13
Sep 17, 2012 01:56 AM
kai-chun
11
Oct 22, 2006 11:03 AM
