Car not starting..electrical issue
Old Nov 17, 2007 | 07:17 AM
  #26
3ghandles's Avatar
yea, i checked the timing and its still on, hasnt jumped. thanks
Old Nov 18, 2007 | 01:13 AM
  #27
bschulz's Avatar
Does your CEL come on for a couple seconds when your turn your key to the ON position? Just make sure there is a good bulb and connection after the swap. Have you checked your firing order and rotor to make sure they were oriented properly when installed? Also, if you've been cranking it a lot I would check or change your oil just in case you have some fuel contamination.
After all that do a compression test. If you've never had this motor running check the basics.
Old Nov 19, 2007 | 09:46 AM
  #28
3ghandles's Avatar
cel comes on and turns of. firing order on the cap and motor good. well change the oil since i have been cranking alot and will take out old fuel since it smells funny and kind of watery.
JdmCrx209
Jul 17, 2011 10:24 PM
3ghandles
Nov 16, 2007 10:15 PM
fuck honda-tech
Sep 21, 2003 06:14 PM
hybrider
Mar 24, 2002 10:32 PM
