Can't Break Cam Pulley Bolt...
Old Jun 17, 2008 | 11:55 AM
Kyoh's Avatar
Default Can't Break Cam Pulley Bolt...
Okay, I've got something that I can't seem to figure out. And I searched all the ways I could and didn't find anything. This may be a stupid question but I'm clueless: How do you loosen the cam pulley bolt without the cam itself turning. Don't have an impact wrench, I need to break this one by hand. Any suggestions? Thanks
Me=
Old Jun 17, 2008 | 03:18 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Can't Break Cam Pulley Bolt... (Kyoh)
long screwdriver in spoke of cam gear resting on surface of head....will work fine
Old Jun 17, 2008 | 03:51 PM
inspyral's Avatar
You can also use 6mm punches inserted into the alignment holes in the cam caps/cams to hold them in place(also at TDC). Or, if your cams have a hex nut casted into the middle of them like LS cams do, you can use a wrench on that to hold the cam in place.
1BADEGDC2
Jul 9, 2008 06:45 PM
TB123
Mar 24, 2008 01:36 PM
OrangeBoost
13
Apr 25, 2006 06:50 PM
f0bulus
Jan 19, 2005 07:34 PM
Quade
Sep 23, 2004 11:07 AM
