can u rebuild a h23a1 twin cam motor ?
i have a h23a1 motor in a 92 auto , with a stufft bottom end , it dont blow smoke the cranks stufft i,ve seen it even the big end shells you could move them , they were loose as ,, can u rebuild the 2,3 motor s if i got hold of a complete extra motor thanks all derek
Re: can u rebuild a h23a1 twin cam motor ?
well, you could certainly just replace the block assembly...i.e. moving anything from your current setup that checks okay onto the replacement block assembly. so long as the replacement matches the old.
hondacivic995
09-02-2006 08:07 PM
y0whuddupb
07-05-2006 10:49 PM
