Can someone post photos of fuel injectors from a B18?
Old 03-14-2004, 11:56 AM
opto_isolator's Avatar
Default Revised - can someone measure the tips of their pintle injectors?
I need to get some custom injectors for my setup. Someone said that the injectors from a B18 would fit - but would like to see some photos of any (if possible) before I drop some cash on them.....
Thanks!
Update, I've seen photos - now all I need are measurements - anyone??? I need the diameter of the pintle tip, plus how large the o-ring is.....
Modified by opto_isolator at 5:10 PM 3/15/2004
Old 03-14-2004, 12:59 PM
onePOINTsix's Avatar
Default Re: Can someone post photos of fuel injectors from a B18? (opto_isolator)
all honda fuel injectors are basicly the same except the H22s which are 325cc i think, Pre 1991 are low impedence, 1992 on are High impedence, no point of running B18 injectors seeing that they are 235cc (i think) just like your your stockers
Old 03-14-2004, 01:07 PM
Default Re: Can someone post photos of fuel injectors from a B18? (Sideout)
Thanks for the info - but I have an 01 civic, and the damn injectors are tiny (2" in length), plus they are not rebuildable (according to RC Engineering). I was going to go with Venom, but I need to know what will fit the injector bosses. The 01 civic uses injectors which have an o-ring at the tip, whereas some of the other styles out there don't appear to have an o-ring. I'm not sure how this will seal up, which is why I need to see some photos. The B18's which I am going to get (if they fit) will have a higher than stock flow rate (390cc's) for the power which I am planning to put down. There are 3 things I need to make sure before I buy them though:
1. What does the connector look like (there are a bazillion connectors out there)
2. What does the injector physically look like
3. Will it fit
I'm hoping that someone will graciously post photos if they have them so that I can tell at least 2 of the 3!
Thanks...
Old 03-14-2004, 02:23 PM
oh sorry, didnt know your setup, bump for some needed info
Old 03-14-2004, 02:28 PM
See first post - need info instead of photos
Old 03-15-2004, 08:11 AM
Default Re: (opto_isolator)
ttt
MyF20b_Prelude
05-30-2015 08:43 PM
DJaeMac
Honda Civic (2001 - 2005)
08-31-2007 09:13 PM
88crxhfb16
08-18-2005 09:40 AM
EVIL_AWD
11-20-2003 04:58 PM
Quick Reply: Can someone post photos of fuel injectors from a B18?
