CAN anyone help??
Old May 4, 2002 | 07:23 PM
allmotor2000's Avatar
Default CAN anyone help??
okay ive explained this problem one too many times already. my 2000 Si is throwing up code 14 and its the Idle Air Control Valve or watevers
I tried cleanign it out...im positive it works because all the volts and stuff are already there when i tested it. theres a click when i pull out the plug with my motor off but in the ON position for the key. It still goes on once in awhile though...im thinking it could be a different IAC valve because on the valve it says 97 on it. maybe its different i dunno. can anyone tell me what else to do?? please??
Old May 4, 2002 | 07:29 PM
Ramnix's Avatar
Default Re: CAN anyone help?? (allmotor2000)
If you unplug the IAC valve while the car is idling, it should dye almost immediately. If I doesn't, then the IAC is stuck in one position, whether its getting volts or not. then rev the motor up and let it come back and it should die. if it doesnt die, then your IAC probably is stuck , and needs replacment
Old May 4, 2002 | 11:21 PM
finaylly some real help...thank you so much. the engine doesnt die ...when i rev it up it just lopes...
thebleek
20
Dec 7, 2008 12:35 PM
marcaobr
Nov 16, 2005 08:09 PM
dayaftertomorrow
Feb 26, 2005 10:11 PM
allmotor2000
May 20, 2002 07:35 AM
