cam seals??
Old Apr 19, 2005 | 03:29 PM
neeks's Avatar
Default cam seals??
turns out this head was missing cams, camshafts, pulleys and cam seals when i bought it so i have to buy some new ones...
now...how many do i need...
im a real noob when it comes to the timing belt/head section ...that whole area is like a jungle to me...
alright so there is only 1 cam seal i need to buy..but arent there 2 more seals? what are they called? i tried to buy a cam seal @ jhpusa.com and they charge 25 bucks for it...the guy told me that i only needed 1 seal so i was like oooooooooooook wtf i got some wrong info..i thought i was supposed to buy 3...can someone give me some info concerning this plz?
Old Apr 19, 2005 | 06:08 PM
oldSCHOOLhonda's Avatar
Default Re: cam seals?? (neeks)
so u need cams/gears and seals? sounds ok so far
u need 1 seal per cam and it goes on the end nearest the gear, d other end allows oil to the distribtor and the dizzy has an oring.
what motor b d ???
u got the cam bearings and rockers didn't u??
Old Apr 20, 2005 | 06:37 AM
neeks's Avatar
Default Re: cam seals?? (oldSCHOOLhonda)
its a b18c1...
uhh im pretty sure i got the rockers and bearings
Old Apr 20, 2005 | 09:56 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
The cam seal you were trying to get is a replacement for the crappy plastic one at the end of the exhaust cam, opposite side of the cam gears. You only need one of those because the distributor connects to the end of the other one. You also need the seals on the cam gear side, which are different.
Old Apr 20, 2005 | 10:05 AM
dwnthehatch's Avatar
You need 2 of part # 24
And 1 of part #8
Get them from http://www.buypartsdirect.com for the best prices.
Old Apr 20, 2005 | 08:34 PM
neeks's Avatar
Default Re: cam seals?? (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">You need 2 of part # 24
And 1 of part #8
Get them from http://www.buypartsdirect.com for the best prices.</TD></TR></TABLE>
wow thanks dude
TheWalrus
Jan 30, 2006 05:47 AM
AznBlueBoy
Jul 11, 2005 08:24 PM
crazzeboost
Jan 23, 2004 12:06 PM
Smoochy
Apr 9, 2003 04:26 PM
