CTR cams?
Old Apr 7, 2003 | 07:41 PM
Smoochy's Avatar
Default CTR cams?
well first things first. this may be a dumb question but do hondas have cam bearing? if so is it a good idea to replace those when the new cams go in? thanks
Old Apr 7, 2003 | 07:53 PM
Smoochy's Avatar
Default Re: CTR cams? (Smoochy)
ttt
Old Apr 7, 2003 | 10:50 PM
Audio28's Avatar
what's a cam bearing.
Old Apr 8, 2003 | 03:51 AM
Xsi's Avatar
Xsi
Nope, maybe change the cam seals but thats about it
Old Apr 8, 2003 | 03:47 PM
Smoochy's Avatar
Default Re: CTR cams? (Xsi)
can you tell me what a cams seal is and ow to replace it please.
Old Apr 8, 2003 | 04:11 PM
allmotorls95's Avatar
the cam seal is a rubber piece that rests at the end of each cam i believe if i remember right there are 4 cam seals ...one set for the intake and one set of the exhaust...make sure u buy some honda bond or some silcon to but around the seal because you have a pretty bad oil leak if you don't
Old Apr 8, 2003 | 04:13 PM
frogsr's Avatar
Default Re: CTR cams? (allmotorls95)
there are two cam seals and one cam end plug.
Old Apr 8, 2003 | 06:34 PM
95 integra's Avatar
Default Re: CTR cams? (frogsr)
The "cam bearings" that you are talking about aren't actually bearings, more like bushings and they are cast into the head/cam caps. You cannot replace them, nor do you need to. Seriously though, you might I want to do some more research before trying the cam install yourself, theres more to it then you might think.
Old Apr 9, 2003 | 04:26 PM
Smoochy's Avatar
Default Re: CTR cams? (95 integra)
thanks
250r king
Mar 13, 2010 10:32 AM
neeks
Apr 20, 2005 08:34 PM
jfoster
Jan 2, 2004 09:34 AM
