cam install question
On this website:
http://www.evotuners.com/camgears.htm
There is a fairly simple description of how to remove/install cam gears.
One part of the description confuses me:
"Mark the timing belt at TDC (top dead center) and lock the tensioner so that it doesn't tighten up when you take the belt off the gears."
What is locking the tensioner, can any one explain this?
The tensioner is near the crank....it puts tension on the belts....think of a big bearing on a spring.
They mean to pull the tensioner back and lock it back so that the belt can slide off easily.
If you plan to replace the belt just cut it. If not make sure you mark which way the belt spun.
I don't really understand the spring/bearing thing, sorry
[Modified by 95GS-R, 9:04 PM 8/14/2002]
Found some better ****.....c-speed, gotta love'em.
Follow link for full on description.
http://www.c-speedracing.com/howto/t...elt/tbelt.html
2. And how does one lock it?
Man that thing looks like a pain the *** to get to.
Heh ... this beats working!
