cam install question
Old Aug 14, 2002 | 11:34 AM
95GS-R's Avatar
Default cam install question
On this website:
http://www.evotuners.com/camgears.htm
There is a fairly simple description of how to remove/install cam gears.
One part of the description confuses me:
"Mark the timing belt at TDC (top dead center) and lock the tensioner so that it doesn't tighten up when you take the belt off the gears."
What is locking the tensioner, can any one explain this?
Old Aug 14, 2002 | 11:40 AM
Spade's Avatar
Default Re: cam install question (95GS-R)
The tensioner is near the crank....it puts tension on the belts....think of a big bearing on a spring.
They mean to pull the tensioner back and lock it back so that the belt can slide off easily.
If you plan to replace the belt just cut it. If not make sure you mark which way the belt spun.
Old Aug 14, 2002 | 12:03 PM
95GS-R's Avatar
Default Re: cam install question (Spade)
How does tension get applied to the belt? If you loosen the tensioner by turning it to the left the belt becomes more slack, correct? How does that work?
I don't really understand the spring/bearing thing, sorry
[Modified by 95GS-R, 9:04 PM 8/14/2002]
Old Aug 14, 2002 | 12:31 PM
Spade's Avatar
I find pics.....
Thanx to Katman.
THe closest thing I can find......see the "wheel" above right of the crank.....that is it.
Old Aug 14, 2002 | 12:33 PM
Spade's Avatar
Found some better ****.....c-speed, gotta love'em.
Follow link for full on description.
http://www.c-speedracing.com/howto/t...elt/tbelt.html
Old Aug 14, 2002 | 12:39 PM
95GS-R's Avatar
1. Ok, so when we pull that wrench straight down, what happens?
2. And how does one lock it?
Man that thing looks like a pain the *** to get to.
Heh ... this beats working!
Old Aug 14, 2002 | 12:51 PM
Spade's Avatar
It will swing away giving you slack to move the timing belt.
I have never bothered with them....had the engine out of the car.
Old Aug 14, 2002 | 01:33 PM
95GS-R's Avatar
Wow ... I just got it. That is so easy it makes perfect sense.
I should get the hammer for not understanding that.
Old Aug 14, 2002 | 01:42 PM
Spade's Avatar
LoL.....at least you admit it
3s1k
Sep 27, 2010 01:58 PM
boomersz
Feb 24, 2007 08:19 PM
d16dcoe45
12
Nov 6, 2006 10:26 AM
RCautoworks
25
Aug 15, 2004 09:17 PM
sivik2nr
Jun 3, 2003 07:43 AM
