Owners with highperformance cam~cams...
Old Sep 25, 2002 | 08:30 AM
1.8Tities's Avatar
Default Owners with highperformance cam~cams...
what kind of oil did you guys used when you installed your cams?
Old Sep 25, 2002 | 09:13 AM
CHEETAH's Avatar
Default Re: Owners with highperformance cam~cams... (4thGSi)
moly lube ...
if you dont have regular 5/30 that you use with motor.
greg
Old Sep 25, 2002 | 09:32 AM
TimoneX's Avatar
New User
Default Re: Owners with highperformance cam~cams... (CHEETAH)
Yep, most cams come with lube for install time. Crower and I believe one other big cam maker recomends dino oil...as in don't use synthetic with their cams.
Old Sep 25, 2002 | 10:16 AM
1.8Tities's Avatar
Default Re: Owners with highperformance cam~cams... (TimoneX)
So 5w 30 Mobil 1(reg oil) should be good right?
Old Sep 25, 2002 | 10:21 AM
TimoneX's Avatar
New User
Yep.
Old Sep 25, 2002 | 10:39 AM
Stupid Ass's Avatar
Sounds right.
Old Sep 25, 2002 | 10:42 AM
TimoneX's Avatar
New User
Default Re: Owners with highperformance cam~cams... (SOHC NoTEC)
If you haven't installed them yet though, and they're brand new, you really should try to get some moly lube. It's much thicker than 5w30 and will stick with the cams better than motor oil during the first few critical spins.
Old Sep 25, 2002 | 10:51 AM
1.8Tities's Avatar
Tim, I got a new billet Crane cam and they send me moly lube should I apply it right now to prevent rusting or something or leave at is? I know I'm gonna use that when I'm installing the cam but I'm just scared it might rust lol.. I have to wait 1-2 weeks to get this installed cause I'm waiting for my cam gear..
[Modified by 4thGSi, 7:53 PM 9/25/2002]
Old Sep 25, 2002 | 11:05 AM
TimoneX's Avatar
New User
Naw, it won't oxidize much between then and now, unless you're storing it in a saltwater bath.
Old Sep 25, 2002 | 11:27 AM
CHEETAH's Avatar
it would also help if you polished cam journals with at least 800 grit sandpaper ... light passes around the journals.
greg
Old Sep 25, 2002 | 12:04 PM
Mover's Avatar
Chilled cast iron ? or their steel one ?
Old Sep 25, 2002 | 02:19 PM
S13 slide's Avatar
i used the lube that came from crower with my cams
Old Sep 25, 2002 | 03:19 PM
IN VTEC's Avatar
Default Re: Owners with highperformance cam~cams... (ridge racer 2)
Is the Redline break-in lube thick?....thick like room temp maple syrup?
I'm just wondering if the green stuff I'm using is thick enough.
Old Sep 25, 2002 | 03:44 PM
TimoneX's Avatar
New User
Default Re: Owners with highperformance cam~cams... (IN VTEC)
Thick like 70 weight I believe.
Old Sep 25, 2002 | 04:23 PM
1.8Tities's Avatar
greg
Yeah, the side of the cam journals are a lil rough on the edges so it's okay to smooth it out?
Old Sep 25, 2002 | 04:47 PM
non-VTEC's Avatar
you guy should go out and buy a bottle of Lucas Heavy Duty Engine Oil Stabalizer.........i find it to be one of the best assembly lubes...........once you see this stuff stick to everything you will know what i mean.....
DFW
Feb 24, 2007 05:09 PM
black cx
Jan 10, 2006 11:18 PM
an2ny888
Feb 20, 2005 06:06 AM
civicracer1993
May 19, 2003 06:07 PM
ravinR68
Feb 10, 2003 04:27 AM
