cam degreeing question, experts only!
Old Nov 17, 2004 | 10:10 AM
builthatch's Avatar
MiG-21 superfan
Default cam degreeing question, experts only!
Ok, So, if it says it should be istalled at an intake centerline of 109, vs. the 106 of the stage 2 which was supposed to be installed such as that with a stock gear (it says that on the bottom of the card for stage 2), I should then have the stage 3 retarded 1.5 degrees from a stock gear (since 1 degree on the cam = 2 on the crank), to meet the 109 intake centerline (i assume atdc) installation on the cam card, right? I understand the playing with sprocket timing, and I will on the dyno, however, I just want to understand the intake centerline info on the card and see if I am right....
Old Nov 17, 2004 | 10:22 AM
TIRENECK's Avatar
Default Re: cam degreeing question, experts only! (builthatch)
them are some big *** pictures, would like to know also.
Old Nov 17, 2004 | 10:32 AM
atcrx's Avatar
Default Re: cam degreeing question, experts only! (TIRENECK)
You should install it straight up or no advance. If you will look at the lobe separation on both cards they are different also. That difference in timing is ground into the camshaft. If you degreed both cams with a degree wheel. At straight up the stage 2 cam should be on a 106 centerline with a 110 degree lobe separation. And the stage 3 should be on a 109 centerline with a 113 lobe separation.
Old Nov 17, 2004 | 11:14 AM
builthatch's Avatar
MiG-21 superfan
Default Re: cam degreeing question, experts only! (atcrx)
ok, thanks, i think i understand, so, on a degree wheel, if the cams are installed like a factory cam, the intake center line for stage 2 will be at 106 and the intake centerline for the stage 3 will be at 109...got it...
thanks again
trav39562
Jan 8, 2009 06:31 PM
hulk_22
17
May 12, 2006 10:58 PM
donnjuan2point2
Apr 20, 2004 11:20 AM
zseeanz
Feb 17, 2004 04:25 PM
ActiveAero
Jan 22, 2003 09:45 PM
