exsohc cam difference
my buddy have a 99' honda civic ex and decided to buy a used crower stage II cam for his car. the cam were for the d16z and after putting it in, his car runs like ****, worst than stock cam. is there a difference from the crower stage II cam for the d16z and d16y? because we looked up the specs on the crower website and it's the same duration and lift for both the d16z and y. any help would be appreciated, thanks!
Re: exsohc cam difference (hulk_22)
So he just slapped a cam in and didn't do anything else. Was there anything done to the heads? Intake? Fuel Delivery?
If crower stage 2 is = to skunk2 stage 2... the companies advise using aftermarket valve springs with a stage 2 camshaft. Make sure that everything's aligned. I just put in a AEM cam gear on my y8, the TDC line was like 1/2cm past TDC and my power has gone to ****, I have IHE and it feels like stock power again. so make sure you aligned everything on the dot.
Re: exsohc cam difference (EH339)
Align it before tuning, you'll have to pay extra if you make them realign your gears. But tuning will get what you're expecting out of your cam.
so is there a difference from the z to y cam? that's what i wanted to know, so there on we can trouble shoot what's wrong. all he has is a intake, running off header, p28 spoon program.
I believe there is a difference between y8 and z6 cams has to do with the dizzy key, I think it throws your timing off, I believe it can be corrected with a cam gear.
sohc guys chime in
sohc guys chime in
Re: (egsleepercivic)
look up the part number for cams, of the y8 and z6..
if there differnt (witch they should be being obd2 and obd1) then u should have ur answer...
i was going to look it up for u, but that is a lot of work right now....
Have a professional fix it. Been messing with my car gear to fix the alignment. Best I could do is retard the gear 2 degrees and I'm back to STOCK power. gonna have my camshaft done by a professional, that way they can time the gear at the same time.
Re: (hulk_22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulk_22 »</TD></TR><TR><TD CLASS="quote">any sohc guys want to put some inputs in.</TD></TR></TABLE>
Only that I have a JDM D15b Vtec engine in my Si at the moment, but there isn't any cam upgrade that's worth it imo. You can only do so much with the engine having one one cam. I'm happier with the high rpm range of this motor over the old z6, but I'm looking into adding a small turbo to compensate for the extra lack of torque in the lower rpms.
xkrazyxjbrkerx75
11-04-2009 10:48 PM
chadalac1712
05-10-2007 06:43 AM
RACING INTEGRATION
03-19-2003 04:40 AM
