Calculated Engine Load = Intake Manifold Pressure ?
Old Mar 14, 2007 | 04:38 AM
AnAccordIsForever's Avatar
Default Calculated Engine Load = Intake Manifold Pressure ?
Recently I was tracking the IM pressure and Engine Load on my OBD-2 scanner and when I saw the chart it was interesting to see how the engine load is like a mirror image of the intake manifold pressure. I used Kpa intead of inHg or psi as units for IM pressure so I can use the same axis/scale on the chart.
In the below image, Blue is pressure, Magenta is Engine Load. (Yellow is timing).
Notice how timing is also mainly affected by IM pressure.
Then I was curious to see at what the IM pressure (and thereby engine load and timing) typically is at what throttle position. Here's what I got -
Blue is pressure, Red is throttle position, yellow is timing.
Interesting to see that around 30% throttle the engine load is already 80-90%.
anybody know where I can find a timing map for this motor (sig) ?
Sampling rate is about 3hz per sensor. So about 8-9hz total.
Old Mar 14, 2007 | 08:15 AM
EE_Chris's Avatar
Default Re: Calculated Engine Load = Intake Manifold Pressure ? (AnAccordIsForever)
Can't help you with the timing map, but what app did you use for the OBD2 datalogging?
Old Mar 14, 2007 | 08:26 AM
Default Re: Calculated Engine Load = Intake Manifold Pressure ? (EE_Chris)
actually I used wOBD for logging the data and pulled the file into Excel to create the chart (wOBD does not have charts, but its free!).
The hardware is OBDPros.com .
Some commercial apps are good but cost almost as much as the hardware.
But there are some free ones that I'd like to try - like FreeDiag.
Modified by AnAccordIsForever at 1:48 PM 3/14/2007
The Weather Man
Aug 13, 2005 10:45 AM
ITR.#1446
Mar 25, 2004 01:02 PM
AdvanTech
Mar 17, 2004 07:16 AM
speedymon
Nov 11, 2003 08:50 PM
crxtreme27
Feb 4, 2003 08:28 PM
