Broken FPR?
Old Nov 11, 2003 | 12:07 PM
speedymon's Avatar
Default Broken FPR?
Troubleshooting some bogging that i'm having from time to time and need to know if this is normal. I have an AEM fpr installed and when i rev the engine the fuel pressure rises up about 5-10psi and then drops back down. Is this normal? I though fuel pressure was supposed to stay constant.
Old Nov 11, 2003 | 01:07 PM
JimBlake's Avatar
Default Re: Broken FPR? (speedymon)
It's supposed to go up & down with manifold pressure. When you open the throttle the manifold pressure goes up (less vacuum), so the fuel pressure goes up to follow that.
Old Nov 11, 2003 | 08:50 PM
DC2NR's Avatar
Dang, dude, you still having problems with that AEM FPR. Well since I installed mine, I haven't had to adjust mine yet. It's still set at the stock setting. However at idle, it's around 25 to 30 or so, and at full throttle it rises up to about 40 or 42. Maybe you need a new spring in it. or something. That bog may be your timing. Did you advance your timing yet. or is it still stock.
91-lsvtecsi
Apr 24, 2012 04:46 PM
MikeNice
May 16, 2006 04:42 AM
ITR.#1446
Mar 25, 2004 01:02 PM
J.R.
Mar 18, 2003 04:38 PM
crxtreme27
Feb 4, 2003 08:28 PM
