Cai diameter for a Ls
Old Feb 6, 2004 | 02:59 PM
shannon's Avatar
Default Cai diameter for a Ls
Which diameter of a Cai would give more power to an all motor LS engine(b18b1)
2.5"/ 2.75" or 3". Which one should you use and why.
Thanks.
Old Feb 6, 2004 | 04:43 PM
shannon's Avatar
Default Re: Cai diameter for a Ls (shannon)
ttt
Old Feb 6, 2004 | 06:01 PM
Kendall's Avatar
I would think that you wouldn't need a very large one for an LS motor, being that it doesn't rev very high and thus doesn't require as much air as a VTEC engine would. I'd just get a 2.5" but I wouldn't get a cold air system. I'd keep the pipe relatively short, as too long a pipe can cause pressure loss and reduce horsepower.
Old Feb 6, 2004 | 06:28 PM
mmuller's Avatar
Mad Scientist
Default Re: (Kendall)
I think aem is 2.75, but if the car is modded i would prolly go with a 3 inch, either cold air or cold air box.
Short ram makes more power, but the underhood temperatures mess everything up, and you'll loose power
Old Feb 6, 2004 | 07:22 PM
notstock93's Avatar
Default Re: (mmuller)
Short rams dont make MORE power, they just make power higher . Its flow quality versus flow quantity. If its a built LS, 3 inch piping would be great. Otherwise, the ideal piping is not so easy to come by. Ideally, you should go from big diameter to smaller diameter (an example of this would be the old ICEMAN intakes or the new AEM V2 intake). These both use different sized piping to make more power.
Old Feb 7, 2004 | 02:52 PM
shannon's Avatar
Default Re: (notstock93)
I have a 3" short ram and I was wondering if I put an AEM CAI if I would feel the difference in power
EG-SIXV-TEC
Nov 4, 2009 12:09 AM
not-a-stang
Feb 21, 2008 03:38 PM
dintegra
Nov 11, 2003 03:05 PM
mugenracer
Mar 21, 2003 07:54 PM
csfalcon
Jun 30, 2002 07:40 PM
