bypassing iacv, fitv
ive searched and cant find the exact answer, i have a victor x manifold and right now the 1/8 inch port is capped off, the blox tb i have doesnt have the fitv. so im thinking ill put a fitting in the im and run a line from there to the nipple thats in the coolant pipe? also make a block off plate for the iacv but keep it bolted in place with the connector still plugged in. let me know what you all think.
thanks
john
thanks
john
I just block all mines off only if the sensor isn't bad "throwing a code for iacv " and adjust the idle screw as needed. You will only notice a problem maybe in the morning and cold days but will soon go away when car warms up. Good luck
RACEPAK
Apr 2, 2006 12:03 PM
