Heat will not get HOT!
Old Jan 12, 2011 | 03:27 PM
90 Si Hatch's Avatar
Icon6 Heat will not get HOT!
YES i have searched and read everything you can possible read. but for some reason my heat will not get Hot. the temperature gauge will read normal and i can even feel the lines on the back of the heater core from inside the car and they are hot.
but i can turn on the blower to high (4) and it will blow almost hot air for about 30 seconds, then go Luke warm. then i turn it off for 30 seconds and back on and just repeat the same thing over and over....
i have read other threads, on which way all the valves should be. but could someone please help me go over this again!
the car is a 1990 Civic Si
Old Jan 13, 2011 | 06:58 PM
spoolinfool's Avatar
Default Re: Heat will not get HOT!
You have a fat air bubble in your heat core. It need major bleeding.
Old Jan 13, 2011 | 07:15 PM
Datunnerkid's Avatar
Yup yup. Or you're heater core fins can be clogged with crud. So u r getting air but no heat through it. U would never believe the things I've pulled out of heater in the way of the heater core
Old Jan 13, 2011 | 07:20 PM
Yup yup, or check if there's anything inside the heater box blocking the heater core so u gots no air flow.
Old Jan 13, 2011 | 07:48 PM
gsrekrevs210k's Avatar
ive been having a problem similar to this one
does that year civic use 2 cables? one from the heat selector switch to a white plastic piece on the bottom of the heater box and then somehow connected (cant explain very well)by another cable to the valve in the engine bay? i broke one of the plastic pieces on mine that somehow controls the heater box vent door and now it swings back and forth. i get open vent(heat) on hard take offs and if i stop quick it slams shut and my heat will go straight to cold. sometimes it goes in between and is warm. if i have the blower on 4, it stays open(heat), but when its at 1 or 2, it sometimes gets slightly closed and becomes warm
i would post pictures to better show you but i dont think im able to on here yet because im a "newby" lol
hope this helps
tjjm36m3
Dec 9, 2008 09:07 AM
batallic
Oct 30, 2008 08:14 PM
nihad
Feb 11, 2007 02:08 PM
newman271
Oct 23, 2006 11:26 AM
type Gendy
21
Oct 6, 2003 02:31 PM
