Burning oil?
Old Aug 15, 2003 | 08:57 AM
Witty's Avatar
Default Burning oil?
I only burn oil above 7.5K RPM. I can see it pouring out the exhaust almost to the point where I can't see the car behind me. I know my PVC is bad because I have oil in my intake manifold but I have had 2 mechanics tell me 2 different things. One said rings, one said valve seals. Any opinions?
Old Aug 15, 2003 | 08:58 AM
mmuller's Avatar
Mad Scientist
Default Re: Burning oil? (Witty)
did you do a leakdown test?
Old Aug 15, 2003 | 09:02 AM
Witty's Avatar
Compression and leak down are fine. 275 across the board and leak down is no more the 10% on each cylinder.
Old Aug 15, 2003 | 09:04 AM
mmuller's Avatar
Mad Scientist
if your leakdown was fine(were was air gushing through?), then it could just be your pcv
Old Aug 15, 2003 | 09:05 AM
rsbad454's Avatar
replace seals and see what happens..........those are a lot easier than replaces rings......but it sounds like you have killer compression.
blackeg
Jun 26, 2011 08:53 AM
jcskyhigh
Jul 25, 2007 01:24 PM
oilguzzler
Mar 7, 2007 08:39 PM
AMChev
Sep 15, 2002 10:26 AM
