Broke Block mount?
Old Aug 24, 2002 | 01:21 PM
crxman2's Avatar
New User
Default Broke Block mount?
I just picked up a 1994 LS motor at the salvage yard . The Compression was
210-210-215-210
1 2 3 4
Here is the problem. As i inspected the motor the driver side aluminum mount was
a little low upon inspection it was sheared off the block. the two top bolts that attach to the aluminum broke out. I was wondering if this was possible to fix or not worth dealing with. the third bolt on the bottom was bent but not broke. The piece that sheared off the block was the top two. It looks like it could be aluminum welded.
Old Aug 24, 2002 | 02:06 PM
rotten's Avatar
Default Re: Broke Block mount? (crxman2)
I've had this same problem on a JDM B16A.
http://www.fatboyraceworks.com/crx/i...6/DSCF0016.jpg
Not a great picture... have one somewhere else.
Basically I just went with a new block because the machine shop wanted about $400 to weld it and tap it again. I have considered taking it to the local technical college and having them use it as a welding project.
I've also considered like shoving a bunch of jbweld in there and just re-tapping it and see if that works. Probably wouldn't but may be a low cost option.
Old Aug 24, 2002 | 02:39 PM
killerprelude86's Avatar
i have the same problem with an a20a3 i just picked up i m going to see how much the shop is going to charge me on monday
Old Aug 24, 2002 | 03:13 PM
ninesecrx's Avatar
Default Re: Broke Block mount? (killerprelude86)
Id just look around for a cheaper place to weld and retap it. You do need to get it done though....thats a major mount.
DCTegg
Aug 23, 2009 12:00 PM
blinger
Apr 18, 2007 07:35 PM
sohczchf
Welding / Fabrication
Nov 16, 2004 12:08 PM
5STAR3
12
Oct 21, 2004 03:42 PM
gsrcivic619
Apr 8, 2004 05:30 AM
