Brakes make noise while driving
I need some brake help. While I'm driving my brakes make a scraping sound. I know its the brakes because it gets louder and makes a squeaking sound when I brake. The car seems to stop fine. I haven't been driving my car because I don't want to damage anything, or have them go out.
Re: Brakes make noise while driving (Lazydsm)
Check your pads. You might be hearing the wear indicators scraping. They will make noise before the pads are completely shot but are not far off from needing replacement. If you have a ¼ inch or less of pad material left, it's time.
just get some new pads. you should be able to inspect them in the caliper. if you can remember what a new pad's thickness is, you'll be able to see if you're wearing thin.
Re: Brakes make noise while driving (vtecb20coupe)
it properly is the piston sticking out too much, check the caliper, make sure all the seal is working so it would draw the piston back when the brake is released.
potatostix
10-26-2005 05:54 AM
Red94Sedan
03-07-2003 10:00 AM
