Brake help!
Old Jul 11, 2004 | 08:37 PM
brucek2's Avatar
Default Brake help!
I don't have a honda but the theory is still the same:
I replaced my brakes wtih Powerslot rotors and Carbotech Bobcat pads all the way around, they are bedded and broken in, this was about 800 miles ago, and yesterday i put some stainless steel lines and bled the lines with motul 600 brake fluid.
and it feels like i have brake pressure but the car doesn't want to stop? I don't know what to do.
Modified by brucek2 at 6:12 AM 7/12/2004
Old Jul 11, 2004 | 09:08 PM
forced00si's Avatar
Default Re: Brake help! (brucek2)
what d.o.t. spec is this fluid and did you drain your system before installing the new fluid? sine brake fluids are not compatible the only fluid that is compatible to d.o.t. 3 or 4 is d.o.t. 5.1 dot 5 is a siliate base and is not compatible with 3or 4
Old Jul 11, 2004 | 09:11 PM
brucek2's Avatar
Default Re: Brake help! (forced00si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forced00si &raquo;</TD></TR><TR><TD CLASS="quote">what d.o.t. spec is this fluid and did you drain your system before installing the new fluid? sine brake fluids are not compatible the only fluid that is compatible to d.o.t. 3 or 4 is d.o.t. 5.1 dot 5 is a siliate base and is not compatible with 3or 4 </TD></TR></TABLE>
its dot 4, dot 3 and 4 are compatible.
Old Jul 11, 2004 | 09:34 PM
forced00si's Avatar
yep they are. are all your hoses straight and not kinked or twisted? also if you have a laser pyrometer you can drive the hell out of the brakes and check to see if you have one or more that are cool. this would indicate a imbalance caused by improper bleeding or mechanical failure of the slides or caliper ect. hope this helps.
Old Jul 12, 2004 | 11:16 AM
Schmitey's Avatar
master cylinder?
Old Jul 12, 2004 | 01:23 PM
brucek2's Avatar
Default Re: Brake help! (Schmitey)
The master cylinder is fine, i'm gonna bleed the brakes again and see if that helps. Maybe some air snuck in there.
Old Jul 12, 2004 | 03:37 PM
Crazydave's Avatar
Do you have good pressure with the car off?
I know this sounds stupid but did you install all the pads properly.
Did you bleed them again
Crazydave's Avatar
Did your master cylinder ever run out of fluid?
Old Jul 12, 2004 | 05:46 PM
brucek2's Avatar
Default Re: Brake help! (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">Do you have good pressure with the car off?
Did you bleed them again</TD></TR></TABLE>
Yah i installed them properly and I made sure the fluid never ran out.
Balut
Feb 24, 2005 08:31 PM
SilverDc2
Jun 6, 2004 08:54 PM
blkgsr03
Apr 16, 2004 09:21 AM
TheOne
Jul 20, 2003 03:28 PM
Cosworth
24
May 22, 2002 07:49 AM
