Bouncing tach
Old Jan 17, 2002 | 08:42 AM
93delsol's Avatar
New User
Default Bouncing tach
when i start up my car, my rpms bounce from 3000 to 1500 rpms. It does this for a few minutes. Why could it do this? I don't have an aftermarket intake btw. It's a D16z6 engine all stock
Old Jan 17, 2002 | 08:48 AM
Spade's Avatar
Default Re: Bouncing tach (93delsol)
IACV (Idle air control valve) is going bad. Take it off the intake manifold and clean it.......check agian if you still have to problem, replace it.
Old Jan 17, 2002 | 08:50 AM
krshultz's Avatar
If the engine isn't moving along with the tach's reading (i.e., the problem is isolated to the tach) , then I can almost promise you it's the ignitor, inside your distributor.
If the engine is wandering, Spade is probably right (though that seems awfully high for the IACV to be causing it)
--Karl, who has had, and fixed, both problems
Old Jan 17, 2002 | 09:26 AM
93delsol's Avatar
New User
Default Re: Bouncing tach (krshultz)
the engine is going along with it. It still goes up to 3000 rpms when it was 40 degrees out or it was 20 degrees out. It almost sounds like the engine shuts off for a second, drops down to 1500rpms then starts again
Old Jan 17, 2002 | 09:27 AM
Spade's Avatar
IACV
Surestick
Sep 6, 2007 02:11 PM
datac99
May 23, 2005 01:52 PM
crxtreme27
May 5, 2003 07:15 AM
IDI2IEIAIVIS
Feb 22, 2003 04:07 PM
