Head bore slightly bigger then sleeve okay??
So my block is sleeved and bored to 84mm. I have a JG B16 head, the chamber has been brought out to 84.5mm from a previous set-up. My question is am I going to run into any major issues with running the 84.5mm chamber of the head on the 84mm block? The block is O-ringed.
Also I'm going to be running a Cometic 84mm head gasket.
Re: Head bore slightly bigger then sleeve okay?? (viet_boi_racin)
I wouldn't like it....I don't think I'd personally settle for it. Your hydrocarbons are gonna skyrocket, plus that's just gonna be a breeding ground for pre-ignition. Your just providing an area in the chamber for the mixture to settle.
Re: Head bore slightly bigger then sleeve okay?? (RC000E)
****! that would mean i either have to sell my head, or have my block taken out to 84.5mm
any other inputs???
any other inputs???
Re: Head bore slightly bigger then sleeve okay?? (.R T E r n i e)
thanx buddy. I'll probably just have the machine shop measure it just to make sure, cause the 84.5mm thing is just what i was told by the previous owner.
